lift pump for swirl pot????
i was having some problems with fuel starvation in the gte when the xe(n/a astra gte engine ) was in i dont think the tank is as good without a swirl pot and a 044 pump to lift from it is as good as i was lead to belive so i am going to fit a swirl pot or its all going to end in tears on the let(calibra turbo engine)
what size is a good size for a swirl pot and what pump should i use as a lift pump to feed it i belive any carb style pump will do but can anyone help ???
I did one for a Escort Cossie once, the swirl pot was about a gallon. Connections were low pressure in, high pressure out and a return to the main tank. Used a high flow low pressure pump from Real Steel that was sized to pump more than the high pressure pump could.
use a decent low lift like a holley or a facet red top, i use a 1 gallon tank, and it goes - low lift > swirl chamber > high pressure pump > fuel rail > swirl chamber > main fuel tank
hth
remember to restrict the flow back to the main tank so you dont empty the swirl chamber
hth
SMILER258
Sep 28, 2015 09:04 AM
