Exhaust
Old Jun 24, 2005 | 04:17 PM
juss 1's Avatar
juss 1
Default Exhaust
What is the best exhaust to fit to my 96N escort cosworth i need to remove the small cat so im looking at a full sytem from the turbo backwards.I dont want to have trouble with it fouling the bodywork or floor ect SO whats the general consensis???
Old Jun 24, 2005 | 07:02 PM
cos jon's Avatar
cos jon
I have a mogoose system on mine (big turbo) with the centre box removed for a bit of extra clearance (and sound!!) i have been told that the magnex are a real good fit as they replicate the original system, so ground clearance shouln't be a problem.
Old Jun 24, 2005 | 07:12 PM
juss 1's Avatar
juss 1
yeah ive been told about the magnex but they only do from the cat back on my small turbo model so it defeats the object unless anyone knows away around it
Old Jun 24, 2005 | 07:29 PM
THE RADMAN's Avatar
THE RADMAN
ggr are an excellent fit,uses different hangers for better clearance,pretty expensive though
Old Jun 24, 2005 | 07:37 PM
juss 1's Avatar
juss 1
WHAT IS THE SOUND LEVEL LIKE AS FOR EXPENSIVE WHAT DO YOU CLASS AS EXPENSIVE NOTHING IS CHEAP ON THESE CARS ASIM STARTING TO FIND OUT.ALSO IS IT AN EXACT COPY OF THE ORIGINAL OR JUST A SINGLE PIPE
Old Jun 24, 2005 | 08:43 PM
chRiS & dawn's Avatar
chRiS & dawn
Had a cat back magnex on mine when i bought it.
I put an early saph 4x4 non cat downpipe on and had the cats removed by a straight through pipe fabricated by my local powerflow exhaust dealer.
It revved up a bit better after this but i have since changed it for a full mongoose system from turbo back and its so much better. And sounds better than the magnex aswell.
Only problem now is mot time. Got through last one but may have to have a sport cat fitted next time.
Cheers Chris
Old Jun 25, 2005 | 09:00 AM
juss 1's Avatar
juss 1
tHE MOT IS NO PROBLEM MY MATE DOES MOTS!! ISNT THE MONGOOSE A SINGLE UNIT THO.
Old Jun 25, 2005 | 10:02 AM
THE RADMAN's Avatar
THE RADMAN
the ggr one is a single pipe, just under £700
Old Jun 25, 2005 | 11:06 AM
juss 1's Avatar
juss 1
No good then im after a system that replicates the original one so i have maximum ground clearance and the hangers are in same place as the factory ones so as not too risk fouling the body work ect cheeRS though radman
Old Jun 25, 2005 | 11:30 AM
Azrael's Avatar
Azrael
Anybody compared Magnex/Moongoose/GGR on rollers?
Old Jun 26, 2005 | 11:39 AM
cos jon's Avatar
cos jon
To be honest i doubt there is much noticable BHP difference between the systems, especially if there all the same size bore with similar straight through rear silencers.
I think magnex have the best looking tail pipe though!!!
Have you thought of a custom exhaust system ?? then you get exactly what you want in terms of fit and sound. My mate had one done and they can tune the sound at different rpm, ie if you want it to be loud at idle but quite during motorway crusin they can supposidly do it !!
Old Jun 26, 2005 | 11:48 AM
Azrael's Avatar
Azrael
Bt Magnex and Moongoose aren't the same bore.
I have custom system. But nothing as sophisticated. Just had some pipes bent and welded together
Old Jun 26, 2005 | 12:11 PM
juss 1's Avatar
juss 1
Apparently the magnex for a big turbo is the exact same exhaust as for the small think ill get in touch with magnex themselves.Or failing that ill buy system from cat back and take original front pipe to an engineers and get them to fabricate one minus the small cat.
Old Jun 29, 2005 | 06:33 PM
cos jon's Avatar
cos jon
There are sometimes front pipes on e-bay for sale from other stainless systems, one thing you do notice is that with a 3 inch front pipe it gets very close to alot of other parts under there !!
Old Jun 29, 2005 | 08:26 PM
Azrael's Avatar
Azrael
The solution is to ake it oval. I talked to custom exhaust company over here and they say it isn't a big technical problem.
Old Jun 30, 2005 | 12:01 AM
juss 1's Avatar
juss 1
cheers lads will try that.
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
