actuator
Old Jun 23, 2005 | 09:01 PM
mikeyrs's Avatar
mikeyrs
Default actuator
will a -31 off a series 2 fit on a 4x4 saph turbo?
Old Jun 23, 2005 | 09:21 PM
richm's Avatar
richm
depends what you mean by 'fit'... they are the same EXCEPT the rod length - 4x4 needs a much longer rod. You can either get an extender kit and use your existing turnbuckle, or a long turnbuckle to make the rod long enough to reach the actuator.
Old Jun 23, 2005 | 09:58 PM
Alvyn's Avatar
Alvyn
Default Re: actuator
think -31's of s2's and 2 w/d Cossies are the same unit but 4x4 and escos actual units are different although still being -31's.
pm stu I'm sure he can/will comfirm for you
Old Jun 23, 2005 | 10:06 PM
richm's Avatar
richm
yep, s2 and 2wd are the same AFAIK, but 4x4 needs a longer rod. The capsule is the same otherwise.
Old Jun 24, 2005 | 05:27 AM
mikeyrs's Avatar
mikeyrs
cheers
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
