S1 Full *CUSTOM* build from shell! *****NOW FINISHED******
Old Jun 23, 2005 | 10:28 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default S1 Full *CUSTOM* build from shell! *****NOW FINISHED******
Soon to be finished so thought i would share a few shots
This is how it has been sitting for the past year untill now
Group N T3 Hybrid 4x4 Turbo with a De - restriced 34mm. .48 Exhousing. Group N oil feed.
Polished and rounded fuel rail and Cosworth fuel regulator, Yellow injectors, Festo connections to vacum for fuel reg to manifold.
Mk5/6 fuel filter with Festo non rubber connections.
Stainless steel braided fuel lines.
Bailey swirl pot with Samco pipes and Mikalor clamps.
Stainless steel Goodridge water lines and connectors.
STD 1.4 CVH EFi Mk5/6 Black rocker cover, with rubber gasket.
Alloy cam cover washers with stailess counter sunk cap heads bolts.
Another shot of the Group N Turbo
Inlet manifold been smoothed and finished in satin black to match the rocker cover. Fitted with the Water temp convertor, ACT convertor. Stainless lock nuts and stainless water pipes to and from the heater matrix.
THE COIL PACK! 8)
Smoothed inlet manifold. Festo connections. Fuel feed to the rail has a valve making it easy to check fuel pressure.
Brand new Throttle body. Festo connection in the inlet manifold with high pressure lines.
Old Jun 23, 2005 | 01:26 PM
CliffRS4's Avatar
CliffRS4
Looking very nice.
Good to see another one being kept alive
Old Jun 23, 2005 | 03:18 PM
adamS2RST's Avatar
adamS2RST
Excellent stuff, looks mad
Old Jun 23, 2005 | 03:26 PM
The Sludge's Avatar
The Sludge
garibaldi
Old Jun 23, 2005 | 06:58 PM
Versus_Creations
Ask me a question!
I checked the engine management today with the ECU from my XR.
Took out the plugs and placed them on the rocker cover while still attached to the leads. So when turning over engine i should see a spark.
Took the plugs off the injectors and using a MK5 escort side light holders in place of the injectors, i can now check that the injectors get a pulse when turning over the engine.
I am yet to run a wire for the fuel pump so instead i connected up a mulitmeter and made sure that the wire was getting 12v with ignition on.
So with no fuel (Cos the injectors are unpluged) and no spark (cos the plugs are on the rocker cover) i turned over the engine and could see the firing order and also the injectors plugs flashing
So the outcome is, that if i have these two parts of the management working and i assume i have compression.......she should start..
I need to take the loom back out and do the final touches to make it fit nice and look nice. Then a little wiring for fuel pumps and triggers etc..
Hope to have her on the road real soon.
Old Jun 23, 2005 | 07:14 PM
pau1rs's Avatar
pau1rs
seen this in the flesh and is mint and a proper spot on build!!!
top work by jano again!!!!!
ps.. still got ya iscv mate!!!!
Old Jun 23, 2005 | 07:34 PM
essexrsturbo's Avatar
essexrsturbo
seen this build all the way through and the attention to detail is bordering on stupidly detailed, things like every clip being individually polished.. should be awsome.
want anymore pics geez? as ive got loads ive been taking along the way
but sod that get on with building my loom mutha fuka!!
Old Jun 23, 2005 | 07:39 PM
Versus_Creations
Ask me a question!
REALLY i will make your loom cook you breakfast if you like
if you can email the pics to me ill post sum up
Old Jun 23, 2005 | 07:43 PM
Versus_Creations
Ask me a question!
Its a MINOR mate glad you getting use out of it
Old Jun 23, 2005 | 07:45 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
get more pics up
Old Jun 26, 2005 | 11:12 PM
Versus_Creations
Ask me a question!
Originally Posted by Freddy_mercury_magic
get more pics up
Ok here we have the Original ford side stickers to be fitted
A little notice to help people move around the workshop
Old Jun 27, 2005 | 12:16 AM
luke89's Avatar
luke89
Team HOTHOT!
looks quality mate well done
Old Jun 27, 2005 | 05:17 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
@ the note
looks minted janno, didnt know them graphics were still avail from ford
Old Jun 27, 2005 | 06:48 PM
LIAMRSTS1's Avatar
LIAMRSTS1
Looking good dude
Old Jun 27, 2005 | 10:14 PM
chiz's Avatar
chiz
its mad and i like it!!
Old Jun 28, 2005 | 10:48 AM
Rossco's Avatar
Rossco
@ the note
When i asked a few months ago they wernt.
Looking good though Jano , but FFS sort a decent camera out
Old Jun 28, 2005 | 12:42 PM
tenpotturbo's Avatar
tenpotturbo
nice work mate
Old Jun 28, 2005 | 09:07 PM
kingpin09's Avatar
kingpin09
Ez jano its the kaz man!!! pow pow. the s1'z lookin sick, pictures dont do it justice.
Look forward to seeing it next time i pop around. Peace, keep up the good work guvnor
Old Jun 28, 2005 | 09:36 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
One to watch.
Old Jun 30, 2005 | 08:24 AM
Versus_Creations
Ask me a question!
Originally Posted by Rossco
@ the note
The graphics have been unavailable for the last 5 years. I have had them hanging around just in case i bought a S1
Old Jul 1, 2005 | 06:07 PM
1900cvh's Avatar
1900cvh
Very nice mate !!!
Thanks for the pulley washer !!!!
Old Jul 1, 2005 | 09:28 PM
Adam Ash's Avatar
Adam Ash
Any piccies of the actual car ?
Old Jul 3, 2005 | 11:55 AM
Versus_Creations
Ask me a question!
Yes mate
Old Jul 5, 2005 | 08:17 PM
Gadget's Avatar
Gadget
Spanner monkey
I've seen this car in the flesh when i was down getting some bits from Jano and it's superb, all the work and neatness of it all is outstanding
Old Jul 7, 2005 | 03:30 PM
Old Jul 7, 2005 | 08:28 PM
RS220Turbo's Avatar
RS220Turbo
Lovely looking mota there brv hopefully you’ll have another one to work on soon. i'l need new stickers brv about 3 of em.
Old Jul 7, 2005 | 10:29 PM
BillyCabrio's Avatar
BillyCabrio
That looks shit hot Jano, i was chatting to one of my mates about you last week. His names Liam, got a S1 - you supplied him all the bits to go cozzie management, hes over the moon
Spoke very highly of you, but then he never told me nothing i didn't already know
Old Jul 8, 2005 | 05:52 AM
Rossco's Avatar
Rossco
Thats better, cracking pics
Old Jul 8, 2005 | 09:04 PM
Versus_Creations
Ask me a question!
Thanks to everyone for their kind words
I started her up today with no errors on the management system and will hopefully start to put her back together real soon...
ESSEX RS Reigional day here we come maybe not on the road due to TAX and MOT etc... will trailor it down
Where you been dude aint seen ya for ages!! Get things together and come over
Yes mate he also has a very nice S1 pic below
Old Jul 9, 2005 | 11:45 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Any bigger pics of the actual car to go with the parts-pics ?
Old Jul 9, 2005 | 08:28 PM
Versus_Creations
Ask me a question!
I will take some decent pics of the inside as i am putting it back together and also the rest of the motor.. It still needs to be flat and polished then polished by hand so will take the final shots of the outside after
Old Jul 24, 2005 | 12:54 AM
Versus_Creations
Ask me a question!
If anyones about tomorrow at the essex rs show come and have a lookski....almost finished
Old Jul 24, 2005 | 08:52 AM
Red16's Avatar
Red16
plenty of bling bits, very nice
Old Jul 24, 2005 | 09:58 AM
RS2000_Daz's Avatar
RS2000_Daz
shit hot matey
Old Jul 24, 2005 | 05:45 PM
rich p xr2t's Avatar
rich p xr2t
Jano_OddKidd, i c it at the essex show mate, very nice
Old Jul 26, 2005 | 08:16 AM
Versus_Creations
Ask me a question!
Thanks for the kind words. The car is 90% done now. Still trying to find silly clips and parts like the washer jets and rubber to go around the wiper in the the spoiler etc..
Going back down the breakers today.
Will update with decent pics real soon
Old Jul 26, 2005 | 01:17 PM
Sticky.'s Avatar
Sticky.
Old Jul 26, 2005 | 03:07 PM
Brian's Avatar
Brian
Look's very nice mate
Brian
Old Jul 27, 2005 | 08:09 AM
Versus_Creations
Ask me a question!
A few i took at the essex show.
I know its not a S1 but its a mk3 which is almost good enough
Old Jul 27, 2005 | 11:24 AM
Linsay's Avatar
Linsay
Got one of these to keep cats away from my car?
