rs turbo ecu question????
Alright peeps,
gonna be chipping my missis h reg 90 spec s2 on the weekend and getting her setup.
I'm stumped on a few things though and what ecu to use.
here's the choices :
1) 90spec - hearts/triangle/hash with superchip fitted
2) 90spec - hearts/triangle/hash with performance turbo systems fitted
3) series1 - blue/red/blue no idea of chip, as i haven't checked yet
Also would it be a good idea to swap the black fuel ecu's over aswell that come with each corresponding chipped ecu?
cheeRS in advance
p.s will the hearts/triangle/hash ecu work in a series 1? i have heard people saying it won't, but then i have seen a freinds one running with a 90spec ecu fitted to it?
cheeRS in advance
option 2 IMO!
reason being ive been impressed with S2's with the TS Chip.
Ive not had any experience with the Superchip 1. (doesnt mean its not as good as option 2 though)
I believe that the S1 ECU does not have a knock sensor where as the other 2 will have.
hth
hth
Sorry M8 I didnt realise that you didnt have the chip, I thought you had the choice of 3 Chipped ECU's, all ready to plug in and it was just a case of which 1 to use!
If you are purchasing new then I'd have a look at the following links!
http://www.motorsport-developments.c...es/rsturbo.htm
http://www.turbosystems.co.uk/products_frames.htm
Worth pointing out that the condition of your engine & way that your car is setup will determine power rather that the quoted BHP of the chip!
sorry mate, i do have 3 chipped ecu's, but what i want to know is option 2 a pts item or turbosystems item? I guess its pts as it states performance turbo systems on the chip.
just wanted to double check really.
also should i pair the fuel ecu's aswell that come with the inition silver ecu? So change both together or just one.
cheers
cheers
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
