COSWORTH GROUP A FUEL PUMP + Need relay terminal info ?????
Hi Guys,
Just about to fit a new group a fuel pump (Bosch 044) ........... Do I need to modify and of the wires.....(Earth lead etc....) ?????
PassionFords Creator
Run 30amp capable wire from the battery to the boot and use a relay to supply it to teh pump, switched on by the existing fuel pump trigger wire.
Be sure to fuse it at teh battery and run through a grommet properly.
Good Point - personally would never put the relay in the boot so never had that issue
All my fuses are about 3 foot from my battery though LOL....
Not sure the pump can pull 30amp to cause the wire to burn out anyway...
its nto really a problem im teasing
but that 3 foot of cable is unprotected from short circuit, so if this wire chaffed and grounded too earth it could so easy turn into a 10KW heater
Originally Posted by dingy
If you place the feed through the existing grommit and stick the fuse in the boot then it don't need to be water proof LOL...
sorry for the late post
Many Thanks guys, on the case as we speak.
From Battery, (8inches of 30am cable), then 30am fuse, then wire ran to rear of car close to fuel pump, connected to relay ????? (Which Terminal ?????)........... Original Pos Wire that went to original pump fitted to relay (Which Terminal ???????) and a third relay tab to fuel pump (Which Terminal ???????)
Just need to clear up which terminals to use on the relay for which wires........ Have Relay with three spade terminals on it .
Jim
Jim
30 would be your new wire from the battery
87 would be a new wire running too your new pump,, same size as battery feed
86 this is where you connect the old fuel pump wire too
85 a ncie grounded lug too the car body
remember too replace the earth of the pump aswell,,, with the same size wire as the batter feed, to a nice clean part fo the chassis
seriously tho, an ideal relay for switching the high current for the fuel pump is the black one from the fuse box on a sierra - it is used to switch the main ignition feed for the car, so go rob one from the scrappies
You guys are brilliant.......
Thanks so much. Just going out to get a length of 30amp wire and some grommets.
Is it best (Easiest) to run the wiring through the car, or under the car ????
Karl will be putting the two halves of the engine together next wednesday, I'll be fitting it friday and Saturday, driving anywhere and everywhere on Sunday, and back to karls for setting up hopefully Monday/Tuesay week after.
This project has been going on for far too long, but at last the end is only days away. Went for conventianal 400+ bhp, and simal torque running a fully modified NMS head and a conventional semi low comp bottom end, with all the right ancillaries (Chargecooler etc) grey's and fully ported manifolds (Inlet) along with one of Vince's (Universal Turbo's) T38's. Expecting 420bhp and similar torque. So will let you know how the next few days go. And it will be put on a rolling road, just for my own damned curiosity. (Any advice at to who's running an accurate Rollling Road at the moment .........With decent Cooling Fans)..... Let me know.
There is a grommet behind the glove box. If you remove the glove box, you should find a plate with relays on it, behind that is a grommet which goes through into the engine below the battery.
If you use that, make sure you re-seal any holes you made in the grommet, or your footwell will be full of water soon.
You should then be able to run the wire along the side of the car, under the carpet, remove the side bolster on the rear bench and run the cable through there, or, under the seat bench into the boot area.
Then, drill a small hole in the spare wheel well, grommet and voila, although I think there already is a hole in the boot floor for the fuel pump (that's where the wires to the trip switch go), so you might be able to use that, or enlarge it slightly.
You might also be able to run it under the car, zip tied to the brake lines for example - much easier, but not very well protected.
Make sure you use grommets everywhere cable goes through sheet metal though.
10-12 meters of red and the same in black will be fine I'm sure, as a side note, I would run the pump earth direct to battery also and use the original fuel pump earth to earth the new relay
right i no this thread is like 3 years old but it's the only one that has a pic of the relay wiring on bosch 044 pump's,
the question i need answering is on the relay, connector 86 is say's connect to car fuel pump wiring for trigger, but i dont have this wire, can i not just run a wire from 86 to the dash to a flick switch and connect up to 30 connector wiring? (main feed from battery)
bit confusing but any help would be great
Yes all you need is 85 and 86, one earth one live does not matter which, as it will still pull contacts closed and work.
The only problem with a flick switch is in the event of an accident, fuel will still pour out maybe out of a ruptured fuel line onto a hot engine, and you may be in no state to flick a switch owing to accident, just a thought.
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
