new alloy rad with pics [ progress]
Old Jun 18, 2005 | 12:00 PM
Combi_Chris's Avatar
Combi_Chris
Default new alloy rad with pics [ progress]
hi all, today im going to remove the front end of my old rusty battered rs turbo combi , remove the grs intercooler , and standard rad, ive been out and got some water wetter , ill be adding a nice alloy radiator....more pics as i progress....
pic 1
pic2
pic 3
Old Jun 18, 2005 | 12:03 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Whats this water wetter stuff im hearing of
Old Jun 18, 2005 | 12:05 PM
Combi_Chris
i have not tried it myself [ yet ]
i have been told it is supposed to keep the water from reaching such high temperatures, if only a little
Old Jun 18, 2005 | 01:45 PM
Combi_Chris
ok heres a wee update.....
intercooler off...
rad off....
by the way , anyone know why there is ia hole on my turbo , and where that plug goes ??
hole.....
plug...
Old Jun 18, 2005 | 03:28 PM
Combi_Chris
any one ?
Old Jun 18, 2005 | 03:44 PM
Combi_Chris
this is how close the fan is.....
and this is now from the front without the bumper/spoiler on...
Old Jun 18, 2005 | 04:20 PM
Combi_Chris
and finally.....
just needs a good clean now , and a good drive to see how much better the average temp is now
Old Jun 18, 2005 | 04:24 PM
Combi_Chris
what ones better ?
old.....
or new
Old Jun 18, 2005 | 04:29 PM
Combi_Chris
i have a q , is it ok to mix water wetter with antifreeze ?
im not sure what way to tackle it , as i was fixing to mix up some antti freeze with water 50/50 ,and i have the water wetter as well ??
Old Jun 18, 2005 | 04:34 PM
Stoo's Avatar
Stoo
That plug is for the reverse light's mate.It go's on the gearbox just to the left of the oil plug thingy You'll see where it go's
Looking good
Old Jun 18, 2005 | 04:37 PM
Combi_Chris
thanks stoo , but i already have revers lights ?
maybe as the loom is 4x4 its not needed anymore,.
Old Jun 18, 2005 | 05:49 PM
Hartyboy's Avatar
Hartyboy
Yeah that plug defo goes on the front of the gearbox mate, nice rad by the way
Old Jun 18, 2005 | 05:53 PM
Combi_Chris
thanks, the plugs still not plugged in anywhere , i have reverse lights so i guess its not used , i have a 4x4 loom so i guess its just leftover or something.
thanks for the feedback too guys....
Old Jun 18, 2005 | 05:59 PM
Hartyboy's Avatar
Hartyboy
Do u have a similer plug on the front of your gearbox then
Where abouts in essex are you mate?
Old Jun 18, 2005 | 06:01 PM
Combi_Chris
im 40 mins from haverhill
based on the m11 between j7 and j8
Old Jun 18, 2005 | 06:43 PM
Hartyboy's Avatar
Hartyboy
When my cars on the road i'll pop over and have a look at ya motor i love combi vans
Old Jun 18, 2005 | 06:48 PM
Combi_Chris
sure, mines still being run in right now, and in 2 weeks time i have another job to do that will make things a lot better
Old Jun 19, 2005 | 01:06 AM
CasperR's Avatar
CasperR
The "hole" on your turbo is for the water feed
The turbo you got is the tbo355 which is water and oil cooled, the S1 turbo (tbo354) is on the hand not water cooled.
You could run it without water but I would suggest running water.
Example
This is a S1 turbo
And this is a S2 turbo, notice the water pipes..
Old Jun 19, 2005 | 12:26 PM
Combi_Chris
where does the feed come from ? and why would it have been left off ? , i dont want to add water then later find out that there is a prob with the turbo and the water and oil have mixed ?
can anyone tell me where the water feed comes from and how i should correctly configure the water cooling on my turbo unit ?
Old Jun 19, 2005 | 12:35 PM
CasperR's Avatar
CasperR
The water and oil will not mix because the housing you have is made so that it is oil AND water-cooled. The standard S2 hose from the rad to the thermostat housing has a small outlet that goes into the big 90 degree pipe.
In this picture you can see the water hose has a small outlet and that goes to the big 90 degree bend pipe. This is where the water runs into the turbo
You need the pipes and bolts off a S2 turbo unit. But if you have had the hole in your turbo for a long time I would flush it to be sure that no foreign objects are in there and could go into the rad.
Old Jun 19, 2005 | 12:45 PM
Combi_Chris
ok so where is the outward water pipe on the turbo, im keeping up so far , i know that the hole is for a feed, so where will the water come back out from, or should i disconnect from the return on the rad and flush that way >?
Old Jun 19, 2005 | 01:04 PM
Combi_Chris
my pipe has no such feed, it goes right from the rad to the therm, and its a samco pipe ? ,im now confused,
now im going to sound really dumb, if the water feed is where that hole is, then where is the exit hole / pipe ?
Old Jun 19, 2005 | 01:31 PM
CasperR's Avatar
CasperR
The is a hole on the other side of the turbo aswell.
Im gonna go get my old turbo bits and see if I can illustrate it.. brb
Old Jun 19, 2005 | 01:38 PM
CasperR's Avatar
CasperR
On the other hand, if you add the watercooling to the turbo you would help your turbo to an easier and cooler life, but your water temps would go up.
Old Jun 19, 2005 | 01:44 PM
Combi_Chris
ive just add an alloy cooler, id rather have the extra water through the unit than not , am i likely to damage the turbo with no water feed?
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
mondeomark
Alloy wheels and ICE for sale
Sep 27, 2015 09:17 AM
liamT74
Sep 23, 2015 10:24 PM
Ben26
Sep 3, 2015 07:55 PM
