t3 unit surging on boost
does anyone know why my turbo is surging ? the cam has been adjusted and seems to have improved things a little, but until i get a chance to replace the cam and set it all up properly i thought id ask if this has come up before ? ?
ok the boost pressure is unstable goes from 12 down to 9 back up to 12 , its set on 08 right now and is holding steady as im running her in, im sure itll be sorted eventually as anything can be . i just thought id see if this has come up before......
i was told when i got the car it needs a new one, then later i was told it was fine .
its not too important right now as im running in, but it will need sorting soon.....
i will find out in 400 miles when shes done 1k and will be ready for full boost set up, but there is an amal valve there , i cant see how its a leaky pipe as its holding strong now even tho its on 0.8
Surge is basicaly an imbalance of pressures between the turbine side and the compressor side of the turbo, this presure (back pressure) enter's the exit of the compressor housing, disrupting flow through the compressor wheel.
Surge is normaly caused by an incorectly spec'd turbo unit.
so what should i do to find out if my unit is incorrectly specced ?
if the problem cant be resolved by any other means
theres no way its the actuator then ? as it seems to be hlding now at 0.8
thanks matey , im pretty sure whatever the problem is will be fixed, i mean its only money right
it might be the actuator it might be more serious, i cant wait to find out actually , lol
i should have some fun though on the way home.....
Mark RS
Oct 12, 2015 06:01 AM
Steve Escos
Oct 1, 2015 06:57 AM
Russ Payne
Sep 25, 2015 08:29 PM
