Cant start my cossie capri!
Old Jun 16, 2005 | 12:00 AM
cosworthcapri's Avatar
cosworthcapri
Default Cant start my cossie capri!
Iv recently installed a cossie turbo engine in my capri but am unable to start it due to no spark.I have the test spark on the first turn of the key but no run spark.iv got a signal to the ecu from the TDC sensor and iv had the loom back out to test the wireing.Changed the distributor,ignition module,still no spark.Any ideas what it could be? or shall i bin the project and get a saff? but thats too easy!
Old Jun 16, 2005 | 09:53 AM
Dave Henshall's Avatar
Dave Henshall
sounds like the phase sensor in the dizzy is plugged in the wrong way round, it will go either way one one way it works, the other is just doesnt. try that first
Old Jun 16, 2005 | 09:20 PM
Niall.b's Avatar
Niall.b
nice mod, will be wicked on greasy roundabouts, cant be too hard to sort out, good luck with it
Old Jun 16, 2005 | 10:56 PM
cosworthcapri
I tried two different distribitors, but il try that anyway.Its also important to get the gap right isnt it? I hope it wont be to hard to sort but been at it for weeks now,looking forward to hearing it running.
Should be fun on wet roundabouts! running stage 1 and its got a limited slip diff.
Old Jun 17, 2005 | 02:41 AM
boost mad's Avatar
boost mad
have u tried changin the coil?
Old Jun 17, 2005 | 07:25 AM
Dave Henshall
gap for the phase sensor just out of intrest should be between 0.2 to 0.3 mm, the tdc sensor should be 0.6 to 0.8 mm,
also if you have the 2 connctors at the back of the dizzy (one is the knock sensor and the other is the tdc sensor) in the wrong plug/socket (yes they are interchangeable) it wont run depending what chip/ecu combination, there are some people that have found it will run but badly with them in the wrong ones, but ive found that mine will NOT run al all with them the wrong way round.
Old Jun 18, 2005 | 12:23 AM
cosworthcapri
Ok, thanks,il try that,iv tried a different coil, that didnt make a difference and another ignition module. Was wondering if it could be the ECU?
Old Jun 18, 2005 | 10:08 AM
Dave Henshall
it could, yes, but 99times out of 100 its a sensor/wiring issue and not the ecu.
are the earth points connected on the engine loom at the back of th einlet manifold,? i ran an additional heavy earth from that point to one of the starter bolts to make sure when mine was messing about that it wasnt just a crap earth through the engine to earth...
Old Jun 19, 2005 | 05:20 PM
cosworthcapri
Dave,cheers, iv changed the plug to the other way on the phase sensor and now i have a spark,got petrol also so just a case of cleaning plugs etc now, i hope! Iv run a couple of extra earths also,so hopefully they are ok.
Old Jun 20, 2005 | 08:18 AM
Dave Henshall
keep us posted
Old Jun 22, 2005 | 09:17 PM
pez's Avatar
pez
can we c any pics of the capri,i fancy the idea of doing a cossie conversion myself
Old Jun 23, 2005 | 10:29 PM
cosworthcapri
Yes im on the case of photos at the moment,but they come up blank on the screen from the photo album when scanned,get it sorted over the weekend.
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Red_bull
Aug 9, 2015 08:34 AM
41
Aug 7, 2015 08:58 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
