Rs Turbo Compression
Old Jun 13, 2005 | 06:47 PM
Daviet's Avatar
Daviet
Default Rs Turbo Compression
im getting valve stem oil seals replaed on my car as car had been smoking on start up on mornings.would clear after half a mile.
the guy doing this said hell do a compresion test at the same time.does anyone now what the figure should be roughly or is it more important that there all very simalar
any help would be much appriciated
Old Jun 13, 2005 | 06:56 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
standard is 8.2:1, but the reading you will recieve will be in PSI/bar not sure what it should be tho
Old Jun 13, 2005 | 07:01 PM
Billabong's Avatar
Billabong
Compression ratio and compression test are two different things.
It's more of a case of the reading from each pot should be similar (within 10% of each other) and do the test dry, and then again, wet.
Old Jun 13, 2005 | 07:09 PM
Daviet's Avatar
Daviet
thats what i was wondering what it should be in psi
Old Jun 13, 2005 | 07:11 PM
Daviet's Avatar
Daviet
its a compression test not the ratio i was after
Old Jun 13, 2005 | 07:12 PM
Billabong's Avatar
Billabong
The figures vary from car to car, wouldn't like to hazard a guess, so up for any RST peeps who've done a test on theirs for comparison.
Old Jun 13, 2005 | 07:34 PM
MK5RST's Avatar
MK5RST
Compression pressure at starter cranking should be about 12 - 14 bar
Old Jun 13, 2005 | 07:35 PM
vroooom ptssssh
It Wasnt Me!
i must be on cloud 9 tonight
Old Jun 13, 2005 | 07:38 PM
Daviet's Avatar
Daviet
MK5RST, so your saying it should be 180psi
is it about 14.9psi to 1bar?
Old Jun 13, 2005 | 07:39 PM
MK5RST's Avatar
MK5RST
vroooom ptssssh, I was very surprized at your post lol, thought u must be f***** Stoned cus ur not usualy dense
Old Jun 13, 2005 | 07:40 PM
MK5RST's Avatar
MK5RST
davS2, The book says 12 to 14 bar
Old Jun 13, 2005 | 07:48 PM
vroooom ptssssh
It Wasnt Me!
MK5RST, My excuse is i had something else on my mind at the moment of posting
i'll have a look in the haynes manual for ye Dave.
Old Jun 13, 2005 | 07:52 PM
MK5RST's Avatar
MK5RST
Ford tecbical data states that pressure, vroooom ptssssh, Hope it wasnt my GF That was on ur mind
Old Jun 13, 2005 | 07:56 PM
vroooom ptssssh
It Wasnt Me!
MK5RST, let's see a pic and i'll tell you if it was her
cant find anything in haynes apart from i was again wrong and just to clarify, the CR of anERST is 8.3:1 someone work it out if we have compression ratio,
8.3:1 cr
1597cc
bore: 79.96
stroke: 79.52
suerly
Old Jun 13, 2005 | 07:57 PM
essexrsturbo's Avatar
essexrsturbo
theres no defined pressure really as even brand new engines are different, but they should all be within 10-15psi of each other otherwise theres a problem
Old Jun 13, 2005 | 08:01 PM
MK5RST's Avatar
MK5RST
vroooom ptssssh, she looks like ur mum but younger PMSL
Old Jun 13, 2005 | 08:08 PM
vroooom ptssssh
It Wasnt Me!
Jeez, i knew you went with munters but....
Old Jun 13, 2005 | 08:09 PM
MK5RST's Avatar
MK5RST
Lol, cheeky c***
Old Jun 13, 2005 | 08:12 PM
vroooom ptssssh
It Wasnt Me!
I know, imagine asking US for compresion test results
Old Jun 13, 2005 | 08:26 PM
MK5RST's Avatar
MK5RST
Yeah mate, no 1 10,2:1 no 2 10,1:1 no 3 9,9:1 and no 4 10,4:1 That wud go down realy well
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
