driving styles to suit a particluar stage of head!!!
Old Jun 13, 2005 | 01:58 PM
keithG666's Avatar
keithG666
Default driving styles to suit a particluar stage of head!!!
....i had no idea that the head on my S1 was a BIG VALVE head, stage whatever with polished this, and ported that....even Gemma (Seve@RSX's wife said "fookin ell, their big ones (with a wink and a smile ")
well, i had no idea, thought it was standard
so, this is all now put back to perfect and ready to go back on the engine....
again, i have an uprated cam but not 100% sure which one....
so, question is...
1) is there a particluar cam that would really suit this head??!?
2) whats the best way to drive (revs, etc, etc) to get the best out of the head?!?!?
hopefully this is not all bollocks that has come out of my mouth but it wouldn't be the first time if it was........
Old Jun 13, 2005 | 02:04 PM
oops, i thought this thread was about how not to elbow your mrs in the face while she is sucking you off on the M5
Ginge !'s Avatar
Ginge !
just finding my feet
keith decide what boost ya want then ill tell ya the cam ya want
a cvh 36 is a nice big bhp cam
a cvh 34 is a good low down power band but tbh if ya just want 200bhp then sell ya head and get a standard head and BRAND NEW standard cam and ya will perfer the lower powerband is gives as ya not into reving ya car are ya
Old Jun 13, 2005 | 02:06 PM
Ginge !'s Avatar
Ginge !
actulayy scrap that as ya going low comp now aint ya
for 220bhp then go for cvh34 or maybe a cvh35 and then have fun, if ya wanna learn how to drive ya car then get a cvh36 and rev the bolloxs out of it and buy double valve springs too
Old Jun 13, 2005 | 02:08 PM
Max's Avatar
Max
remember it's keith driving
you might aswell lower the rev limit to 4k coz he drives like a
Old Jun 13, 2005 | 02:12 PM
Ginge !'s Avatar
Ginge !
yeah but hes gonna have to sort that as hes got a low comp engine.hybrid turbo and big vavle head
he needs EFI managemt tbh to get the most out of it too
Old Jun 13, 2005 | 02:17 PM
Max's Avatar
Max
I have told him to go efi but it's too much money for him to justfy spending
Old Jun 13, 2005 | 02:20 PM
Markb_s1's Avatar
Markb_s1
1: I would expect this depends on the specifics of the head!
2: I would expect this depends on the specifics of the head... along what spec the rest of your engine is built to!
Old Jun 13, 2005 | 02:22 PM
keithG666's Avatar
keithG666
too much money at the moment i'm afraid....
but i'm not getting rid of the head...its good PUB AMMO!!!
i'll rev it i tells ya.....i'll rev it like it has never been revved before!!!
Old Jun 13, 2005 | 02:23 PM
keithG666's Avatar
keithG666
ginge...i want to run approx 22psi
Old Jun 13, 2005 | 02:26 PM
Ginge !'s Avatar
Ginge !
cvh 35 or 36 then
speak to dazc and rick and ask em what there using
efi aint that much cash matey
just need a efi loom, 3 bar and ill drill the block before ya fit the engine then all ya need is a addaptor plate and ya there
seriously drill the block though and get that part ready
Old Jun 13, 2005 | 02:32 PM
Max's Avatar
Max
omg. don't let him near powertools
Old Jun 13, 2005 | 02:36 PM
keithG666's Avatar
keithG666
cvh 35 or 36 then
so how come it cost dan ŁŁŁŁ and you can do it for a packet of wine gums and a bottle of hooch?!?!
Old Jun 13, 2005 | 02:56 PM
Ginge !'s Avatar
Ginge !
keith im not sayting its fook all but DIY is gonna be alot cheeper !!!!
not getting the 1.8 pully and drilled the block proper will be fook all in cost !!!, the cps holder is 3 quid from fords
you get a efi flywheel and efi loom from a orion,xr3i 90 spec or xr2i and pin swop 3 pins to convert it, buy a 3 bar mapsensor ( there 60 quid these days ) and then ya just need a addaptor plate as im not gonan be happy dremeling ya head for some reason
then buy the ofab ecu for 100 quid and then get it live mapped by grove and ya sorted
infact its ever cooler a idea as ya can use the top half of ya inlet and the bottom half of a efi inlet and then nobodys the wiser, then ya sell on the other junk to regain a bit of ya money (50 quid for a s1 metering head for example) and then ya also make a doubloe saving as the cars gonna be much much better on fuel too
dan payed for people to do it and as a result he got a job done that he wasnt fully capable of doing but he also went for cossie management too with is abit more involved too
it sounds alot harder than what it actually it, i would drill the block ( gotta be acurate and spot on btw) and fit the holder and flywheel just incase as the engine is already out
seriously i will drill the block for ya, ive done it already and still got me stencil for it too
Old Jun 13, 2005 | 02:59 PM
keithG666's Avatar
keithG666
@ stencil!!!
sooo...if you drill my block, but don't actually go for EFI until whenever....will it leak?
Old Jun 13, 2005 | 03:03 PM
Ginge !'s Avatar
Ginge !
no you gimp
its a hole on the end of the lug to allow the sensor to see the flywheel, buy a efi flywheel ( its the same as a s2 flywheel but has lugs for the cps sensor to read) and aill drill the block and if ya dont go efi ya aint lost anything
if ya do then ya save 100 quid in pullys and the hassle of sourcing the stuff
Old Jun 13, 2005 | 03:04 PM
Gra's Avatar
Gra
geek
Old Jun 13, 2005 | 03:05 PM
keithG666's Avatar
keithG666
christ....
sounds a bit complicated!!!
Old Jun 13, 2005 | 03:08 PM
Ginge !'s Avatar
Ginge !
ya are kididng aint ya
its sooooo fooking easy mate
infact max's flat mate can even do it i recon as hes alot better on cars than me
think of the good thing about efi, cheeper petrol, acurate fuling, witha 36 to 1 flywheel ya can fit aftermarket management like omex or emerald too and have a ultra bling management
i personally at this stage would do it just cause ya can
Old Jun 13, 2005 | 03:13 PM
keithG666's Avatar
keithG666
will it chatter?
Old Jun 13, 2005 | 03:15 PM
Max's Avatar
Max
yep
Old Jun 13, 2005 | 03:16 PM
Ginge !'s Avatar
Ginge !
will it chatter?
i wpuld have sent that via pm to avoid embaresment
all the techy stuff it doe so ya engine will live longer and YES it will chatter
Old Jun 13, 2005 | 03:22 PM
keithG666's Avatar
keithG666
good....then do it!!!
will it chatter by drilling the hole?
Old Jun 13, 2005 | 03:24 PM
Max's Avatar
Max
so do ya need an efi unit and injector rail.
I know someone who has one for sale
Old Jun 13, 2005 | 03:26 PM
keithG666's Avatar
keithG666
i prefer the words 'cheap' or 'free'
as long as they come under one of them...i'll have them!!!
Old Jun 13, 2005 | 03:27 PM
Max's Avatar
Max
cheep as chips
Old Jun 13, 2005 | 03:29 PM
keithG666's Avatar
keithG666
i like that!!!
how much?!? who's it from?!?! put my name down!!!
and warn Dan.....as his wheezy old oil burner is gonna get beaten!!!
Ginge !'s Avatar
Ginge !
i know ya flat mate has one for sale hence why i also sugested it
he might also still have the flywheel too but cant be sure on that
Old Jun 13, 2005 | 03:34 PM
Max's Avatar
Max
nah I think the flywheel is still on the engine which is in his car, but I will check.
and the efi unit is complete with injector rail and injectors
Think he wants Ł20 ish for it. Will check that aswell
Old Jun 13, 2005 | 03:35 PM
Ginge !'s Avatar
Ginge !
good price and has the throttle and tps on it too
Old Jun 13, 2005 | 03:39 PM
RichardPON's Avatar
RichardPON
What the fuck?
Ginge drilling your block? Good lord help us
Old Jun 13, 2005 | 03:41 PM
keithG666's Avatar
keithG666
SOLD!!!!!
and richard...you have no faith!!!
Old Jun 13, 2005 | 03:43 PM
Ginge !'s Avatar
Ginge !
What the fuck?
ironicly pon ive drilled a block and also dremeled a head and the only problem the guy had with his car the following week was he fucked his gearbox
guess that means it worked then
infact i started that and finished it in a week, hows you track car build going on
things are easy IF ya know what ya doing, just cause ya dont understand how to do it dont mean it dont work
Old Jun 13, 2005 | 03:46 PM
RichardPON's Avatar
RichardPON
Ginge - you put a post up last week asking what something was that you could see through an inlet port, and didn't realise it was a valve!
I'm not knocking your drilling ability, but if you fuck it up, are you gonna lay out for a new block?
Since you're also so concerned, my track car build is going very well thanks. The difference is that I like my stuff done properly, so it takes a lot longer and costs a lot more.
Max's Avatar
Max
Originally Posted by keithG666
SOLD!!!!!
Did I say Ł20 I meant Ł40
Old Jun 13, 2005 | 03:50 PM
keithG666's Avatar
keithG666
Ł20...i ended the bidding at that.....its when the hammer went down!!!
hold on.....so drilling this ere little ole could fuck the block up!?!?!?!
great!!!
Old Jun 13, 2005 | 03:51 PM
keithG666's Avatar
keithG666
(theres some right old BODGERS & BADGERS on here!!!)
Old Jun 13, 2005 | 04:05 PM
Ginge !'s Avatar
Ginge !
pon seriously how can ya say that drilling the block would make it totally fooked up
its a hole on a part of the block that has no use
the only problem i could cause it drilling it off the correct point and that would cause the car to missfire, hence why i take my time doing it, i never offered to fit his pistons to his rods as thats a proper job and also notice ive sugested he gets a efi addaptor plate as that job if done wrong can fook the flow of the engine
also about my askign what the VALVE GUIDE was it was cause it was at the wriong angle and that was caused by the flash, i know what a fooking valve guide is, im not totally stupid with things and i find CVHG's easier to work on and also find i understand efi better than mfi hence why i sugested him doing that as fault finding is easier and also if he gains a air leak he dont neeed a tow home
i seriosly thing ive gotta stop taking the piss about all thwe work i do as people do belive i just hit and hope and not research what i do
oh and if i did fook it up ( which i wont as its not like its a first attempt and i got my first attempt SPOT ON too i would obviously sort the damage as im not a person top fuck somink and then change me number
keith seriously if ya are worried then dont do it that way but dont let another persons fear and lack of knowlage put you off as hes nerv attepmted it to see how easy it was
infact christan said cutting though a cvh block was like a knife though butter and said that even I ( myself not christian) sould have no problems, he also used a tol ya would not belive and 163mph kind of shows it works, infact im suprised he dont go on about the 1.8 dont work as hes fastest 1.6cvh has that on it makming it far superiour
pon seriously i do tak the piss but when have ya EVER seen my work cause a fook up of any kind and notice i do post when i make mistakes ect
ive not blown my engine up and the xr2 with the bodged conversion has a slight part of surge ( hoooge turbo for the valve and cam timing) but its only managed to fookmthe gearbox and that was due to raggin the arse off it with no oil
pon things that cost 4million quid dont mean its the best either !!!
again ill use christian as a example, he was using skimmed pistons for ages and done some really good times, shows its just the thought and planing and not the money lobbed at it
Old Jun 13, 2005 | 04:12 PM
Ginge !'s Avatar
Ginge !
before
middle
getting close but i blunted the drill bit
after
i also done this but i dont recomend it at all , this was my engine i was selling and if i fooked it i never sold it ,thats 400 quid down the drain, how big is ya bollox indead
all sorted and running ( i confess i forgot to tighted the sump plug when doing the oil change , that was the only issue that i forgot to solve, i also HANDMADE a inlet gasket to overcome the efi inlet to thje new addapted head too
but it worked and i was suprised but my mates had faith in me
Old Jun 13, 2005 | 04:21 PM
RichardPON's Avatar
RichardPON
Whatever mate - no offence, but maybe you should be a bit more choosy what you post about your own mechanical skills, as judging only from what I've read of your work on this board, I wouldn't let you change my interior light bulb
