Top Boost Hose
Old Jun 13, 2005 | 01:27 PM
Big AL's Avatar
Big AL
Default Top Boost Hose
Anybody got one local to Colchester ?
Car is running a tad rough so want to take the DV off and see if this is the cause.
Old Jun 13, 2005 | 03:08 PM
bzd32's Avatar
bzd32
just take the dump valve off and plug the hole up with abit of a brush handle or something like that.
just save you taking the pipe off
Old Jun 13, 2005 | 04:49 PM
swanny's Avatar
swanny
Both myself and my bro (doggydowg) are running the broom handle mod at present.. feels so much better to get the old naff dump valve off
Old Jun 13, 2005 | 04:50 PM
swanny's Avatar
swanny
Forgot to add, to make sure u block or remove the t piece that goes from the ecu hose to the top of the dump valve... probabally wouldnt run too nice with that left loose.
Old Jun 13, 2005 | 05:08 PM
james_birch's Avatar
james_birch
get it off! ...broom stick is fine...broom broom!
Old Jun 13, 2005 | 05:37 PM
gus's Avatar
gus
i will have a look tomorrow for you pal
not home til then
i have a box full of samco's, not sure where any of them now
Old Jun 13, 2005 | 08:36 PM
bzd32's Avatar
bzd32
i still run a dump valve (i just like the sound) but thats me
its just away to plug it up cheap
Old Jun 13, 2005 | 08:54 PM
rs_daz's Avatar
rs_daz
I got the broom handle mod too
Old Jun 13, 2005 | 09:38 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
me too
mine was a screw fix 1 that snapped the 1st time we used it at work
my car is runnin 100 times better now, slower reboosting between gears but its running loads better and teh timings been better to wet up now its off too
Old Jun 13, 2005 | 11:06 PM
AKRS1's Avatar
AKRS1
Do be honests i used to like the dump valves before bcos of the sound but after blanking mine of last week it wont be going back on. Runs so much better and smoother. I use my car daily on the dual carriage ways and with the dump valve the cr used to jerk alot whle i was in 5th gear coming on and off the throttle but now with it blanked off it drives perfect with no jerks, idling problems or any rough spots and i can hear a little chatter too
Old Jun 13, 2005 | 11:09 PM
1.9 xr2 on 40's
st170 breaking
my bleedvalve fell loose today (blood engine mount is goin and a pipe got pulled of it ) and car was running daft boost til i got home, fook it was chatterin
mite stuff my efi lump in it now while im changin the box
Old Jun 14, 2005 | 03:12 AM
Big AL's Avatar
Big AL
Broom handle mod it is then, cheers chaps
Broom Broom FPMSL
Derek Burleigh
Sep 16, 2015 06:27 PM
3drRich
Sep 13, 2015 07:32 PM
martysmartie
Sep 6, 2015 10:22 AM
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
