Removing Esc Cos fuel pump - need the tool?
Old Jun 13, 2005 | 11:52 AM
DaveEscos's Avatar
DaveEscos
Default Removing Esc Cos fuel pump - need the tool?
Is there a way of removing the pump without the 'ford tool'
looks pretty grotty aswell anyone got the microcat diagram of what can be replaced?
Old Jun 13, 2005 | 12:08 PM
3drstretch's Avatar
3drstretch
This any good.
Old Jun 13, 2005 | 12:11 PM
jasonp's Avatar
jasonp
Dave i took mine out just knocked the locking sleeve round with a hammer and flat head screw driver
Old Jun 13, 2005 | 12:26 PM
DaveEscos's Avatar
DaveEscos
cheers stretch
Jase, yeah.. looks like the previous people did that.
anyone run aeroquip from an intank pump set up?
im thinking im going to have to get -6 males brazed on to the two pipes outside of the tank?
Old Jun 13, 2005 | 02:38 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can make a tool by taking a piece of tubing that will fit over the pipe and into the spring joint. just slice the tubing down one side so that you can open it up and put over the pipe, then close it back up around and slide into the spring joint to open it up. job done.
Old Jun 13, 2005 | 03:21 PM
GUZZLER's Avatar
GUZZLER
the lock ring is only about Ł1.50
Old Jun 13, 2005 | 06:35 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
just knock the ring round, i've got aero's to the filter and from filter to tank
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
