Split Rims!?
Old Jun 13, 2005 | 07:36 AM
B19-TRB's Avatar
B19-TRB
Default Split Rims!?
Do split rims have to be torqued!?
or is it just a case of do them up as tight as you can!?
Old Jun 13, 2005 | 08:01 AM
DAN P's Avatar
DAN P
your car is so slow you will not need to do them that tight o and thanx for coming up my road early today
Old Jun 13, 2005 | 08:04 AM
GARETH T's Avatar
GARETH T
what bolts are you on about? the holding the wheels too the hubs, or holding the outer part of the wheel too the inner?
well both need to be torqued
Old Jun 13, 2005 | 08:05 AM
B19-TRB's Avatar
B19-TRB
i specifcy gave it a bit more just to make sure I woke yer ass up! ave it!
least my car runs!
Mikey came back & said it grips to well arse dont come out!
so he had to be shown! so i actually gave the car some abuse & did a lil drifting! u missed it!
Old Jun 13, 2005 | 08:06 AM
B19-TRB's Avatar
B19-TRB
the bolts that bolt th wheel together!
is it just a case of do em up as muhc as poss gareth! or am i gunna actually have to find torque settings for them!?
Old Jun 13, 2005 | 08:09 AM
GARETH T's Avatar
GARETH T
a torque setting is always better
Old Jun 13, 2005 | 08:12 AM
B19-TRB's Avatar
B19-TRB
where the fook am I gunna get that for a set of jap rims!?
Old Jun 13, 2005 | 08:15 AM
Daveyboy's Avatar
Daveyboy
Japan?
Old Jun 13, 2005 | 08:16 AM
B19-TRB's Avatar
B19-TRB
Old Jun 13, 2005 | 08:17 AM
3drstretch's Avatar
3drstretch
Yes they need torqueing and Locktiteing.
Old Jun 13, 2005 | 08:20 AM
B19-TRB's Avatar
B19-TRB
u recon the torque settings r rim specific shorty!?
what r the settings for your rims!?
Old Jun 13, 2005 | 08:26 AM
DAN P's Avatar
DAN P
mine runs m8 only on 3 but it runs might go over tonight and do it and fook me i did miss it as that aint going to happan again
Old Jun 13, 2005 | 08:30 AM
B19-TRB's Avatar
B19-TRB
fookin shonk!
Hopefully John is gunna do my oil temp gauge today! will get him to do the zorst blow as well & then might actually play with the boost controller! but probably not as Im to lazy!
Old Jun 13, 2005 | 08:34 AM
3drstretch's Avatar
3drstretch
Dont know about being rm specific.It is not a tight setting IIRC.Mine were around 10 Nm or Lb will check when i go home later.
Old Jun 13, 2005 | 08:39 AM
rs cos's Avatar
rs cos
Lewis give image a ring, I'm sure renton has the number if you can't get it.
Old Jun 13, 2005 | 08:43 AM
B19-TRB's Avatar
B19-TRB
Ok fella will give them a shout if i cant find anythin out!
google gives this address for the rims i have
www.speedstar.co.jp
but it dont load for me!? any1 else get on it!?
Old Jun 13, 2005 | 08:47 AM
3drstretch's Avatar
3drstretch
Wont load for me neither mate.
Could also try Compomotive as that where i got my bolts from. 01902 311499
Old Jun 13, 2005 | 08:48 AM
B19-TRB's Avatar
B19-TRB
u got a emial or web addy for them!? & for image!?
Old Jun 13, 2005 | 08:54 AM
rs cos's Avatar
rs cos
http://www.imagewheels.co.uk/
Old Jun 13, 2005 | 08:57 AM
3drstretch's Avatar
3drstretch
www.comp.co.uk
B19-TRB's Avatar
B19-TRB
cheers fella!
i emailed both image & comp!
Old Jun 13, 2005 | 05:13 PM
Eagle's Avatar
Eagle
Super Moderator
can you let me know what comp say please lewis
just found this from compomotive
Great care should be taken in removing the bolts ensuring that the allen key drive provides a good positive location in the fixing . Retain pressure on the fixing whilst removing the fixings to ensure the heads of the stainless bolts are not damaged
Retorquing should be 12~14 Ft/Lbs using Loctite 242 threadlocking fluid.
Tighten all bolts down first, then undo and apply Locktite to each bolt and retourqe individually opposing each other.
Old Jun 14, 2005 | 07:20 AM
B19-TRB's Avatar
B19-TRB
Pete this is what Mark form Comp emailed me back!
The torque setting for the fixing bolts would be based on the size and grade of
fixing used.
Our 3 piece wheels using M6 bolts are torqued 12~14 ft/lbs and the M7 fixing 14~16
ft/lbs. You could use this as a guide.
Old Jun 14, 2005 | 08:17 AM
3drstretch's Avatar
3drstretch
Wasn't far off then was i.
Old Jun 14, 2005 | 08:23 AM
B19-TRB's Avatar
B19-TRB
Nope!
basically just gotta look @ what size bols my rims use!
How do u measure a bolts size!?
Old Jun 14, 2005 | 09:01 AM
rsnissan's Avatar
rsnissan
what rims are they lewis ?
Old Jun 14, 2005 | 09:07 AM
B19-TRB's Avatar
B19-TRB
Speedstar (SSR) Longchamp XR4Z
Old Jun 14, 2005 | 09:09 AM
ste_gt's Avatar
ste_gt
http://www.gizmology.net/nutsbolts.htm
Old Jun 14, 2005 | 09:11 AM
ste_gt's Avatar
ste_gt
This may be a bit easier for you to read.
Metric Fasteners
Metric fasteners material, head style, and type are described in a similar manner to US fasteners. However, instead of threads per inch, the metric system uses thread pitch (the length of each thread in millimeters measured along the shaft of the bolt). The thread pitch is written between the diameter and length (both measured in millimeters) and is separated on each side by an X.
Typically the diameter of a metric bolt is preceded by a capital M to designate metric.
Example:
Class 8.8 Hex Bolt M10 x 1.5 x 20
This is a hex head bolt with a diameter of 10mm, a 1.5 thread pitch, measuring 20mm long and made of Class (grade) 8.8 steel.
Old Jun 14, 2005 | 09:38 AM
rsnissan's Avatar
rsnissan
try using a torque wrench to see what they are set to youve got 120 of the fuckers to try and wittle it down to the correct setting
Old Jun 14, 2005 | 09:41 AM
B19-TRB's Avatar
B19-TRB
Old Jun 14, 2005 | 09:46 AM
Ryan's Avatar
Ryan
wheels look awesome lewis.
hopefully pick mine up from the painters today
Old Jun 14, 2005 | 09:54 AM
The correct torque setting for the bolt is the key thing, not for the wheel.
I used to run some *really* lightweight splits on my mini trackday toy i used to have, and the wheels were so on the limit for strength (they redesigned an existing wheel with two less bolts to save weight) that they used to reguarly pop the bolts off as you were driving along.
You would hear them ping off as you were driving along, then you have to stop the car, jump out with some extra bolts and torque to 17lbft then off you go again.
Old Jun 14, 2005 | 10:24 AM
B19-TRB's Avatar
B19-TRB
pmsl @ chip!
Cheers Ry! Nige has 1 @ the moment he is polishing & powder coating it for me!
Old Jun 14, 2005 | 10:38 AM
gurnE's Avatar
gurnE
About fookin time you put some half decent wheels on that SX mate
Scared the shit out of me the first time it happened, i had only just installed the engine id built for it and was still running it in.
i was driving up the M5 at about 60mph or soand heard "ting" and the distincive sound of a bolt bouncing off the car.
I thought "oh, what a coont, must have left a loose bolt in the engine bay, thats not like me, oh well...."
Then a minute later "ting" and same noise, then a few seconds after another one, then another.
No way that was healthy so quickly pulled over and one front wheel was missing a third of its bolts and a couple missing from the other (shows how exactly they are made that both failed together like that)
So after that i had to make sure i always had a small torque wrench and a set of bolts with me just in case
And at coombe etc i always checked them every session obviously.
Awesome wheels though
Old Jun 14, 2005 | 10:44 AM
B19-TRB's Avatar
B19-TRB
Standard 1s r on there @ the mo!
I hope mine aint that bad chipper!
Old Jun 14, 2005 | 10:48 AM
gurnE's Avatar
gurnE
They are better than those shonky Nissan Terrano rims
Old Jun 14, 2005 | 10:53 AM
B19-TRB's Avatar
B19-TRB
it was only the tyres that were off a terrano!
but yea seen a lot of 200sx with the skyline rims on so least there aint many sets of them splittys around in the UK!
Old Jun 14, 2005 | 03:32 PM
Eagle's Avatar
Eagle
Super Moderator
bruce had that problem with mine chip .. did donnington one year only to find half the bolts on one side had come off/loose
