anyo0ne know about ford galexy gearboxes ??
i got a mate who needs a clutch doing in his 2.3 gallexy and was wondering if anyones done one before and how difficult is it compared to a erst gearbox
looks like its gotta come out the bottom and i think its a VW engine fitted to it,
all help and advice would be cool
its the same style as a vw engine
, inlet at the front zorst at the rear and looks like a vr6 engine
its got a clutch release bearing issue , wont select gear as its not releasing the clutch
just wondering does the hydro clutch fluid feed from the brake fluid or it there another resivoir
its a nice car, shit i must be getting old
deffo aint a rs2000 engine though
im telling you its a 2.3 and dont have a efi inlet
its got that manifold looking thing like the VW engines, same type of LOOK as the seat 1.8 16v engines
take a piccy of yours and ill tell ya if its the same
i aint got me camera with me
back on topic, anyone care to answer the questions
, i really dont care what engine it is btw
, was just saying what it looks like and i thought it was
ok the oil filler cap aint in the same location and the front of the engine has the metal thing like the 16v golf engines have
is that the wrong engine then
the oil filler cap is hooooge and its in the middle on the engine bay/ gearbox side if engine
I have heard there was a 2.3 V6, i have never seen one though but it may be what you have.
Engines were 2.3 I4 RS2000 lump, 2.0 SOHC VW PB engine ala golf GTI, 1.9 tdi vw engine & the 2.8 VR6 golf engine.
It is a big box though as has been said, the clutch feed is from the brake reservior and the slave cylinder is part of the release bearing i think.
You'll have to take the battery out as the mount is under there, the shafts will have allen key bolts and the linkage is cable so no real troubles there.
Well I can only speak from experience. But we were doing 6 hours labour on Sharans. You have to BOLT the engine support to the front wings due to the steep angle the bonnet sits at. Battery and battery tray out just for starters.
Proper Proper Wanker job
what about out the bottom as from the top does loom a cooont and so i wasnt gonna domit that way
if it is a coont then ill just wait for another time he needs a favour like fitting a stereo and do that for him
he payed 400 quid for it ya see
Rich_w,
These are without doubt the WORST cars Ive ever worked on (Sharans) In terms of shit you're going to deal with, Id pay someone else
Rich_w,
fookinell man , there a pretty straight forward job, done loads and loads now , i work in the VW group and think the sharn/galaxy/alhambra are an easy vehicle to work on, a clutch change by the book is 4.7 hours , less than 3 in reality to do with a bit of experiance , tho the VR6 variant is a bit of a pig,
but to answer the Q, not too bad to do
Originally Posted by markk
Rich_w,
Rich_w,
And Plug change on a VR6 Sharan.Nothings impossible, but not much bloody fun either.
I'll admit though that I really dont care about them. Probably started when they had that brake recall issue a few years back.
Much prefered doing Golfs and Polos
Rich_w,
Ever changed the Ecu on one?
come on how very wrong man, dash clocks out ... yes , not the dash
What about the fooking Pollen filter
early ones are a piece of piss man, later type charcoal impregnated are even thicker - slightly more difficult but no need to remove anythin extra
Re : The ECU. Oldish car. One of the first IIRC (remeber this was 98) The bracket that holds it in broke. So like you say normally clocks out. But when the bracket breaks, you cant get a screwdriver (even a stubby) in to undo it. So we had the entire dash out to change a stupid bracket.
Oh and dont get me started on their in-ability to keep rain water outside the car.
You're very defensive about these heaps of crap. Do you work for VW?
We were forever saying "Stupid Ford design" and the guys down the road at Fords were probably saying "Stupid VW design"
Rich_w,
conveniance unit under the seat in 4" of water ? dont know what your on about
You're very defensive about these heaps of crap. Do you work for VW? We were forever saying "Stupid Ford design" and the guys down the road at Fords were probably saying "Stupid VW design"
van_dogg_pavvy
Mar 3, 2016 09:30 AM
borboyous
Aug 22, 2015 11:17 AM
