valve collet fell down oilway! (i think there called that!)
Old Jun 11, 2005 | 02:57 PM
andre_k's Avatar
andre_k
Default valve collet fell down oilway! (i think there called that!)
hey was trying to change me valve stem seals with my own homemade tool, however one half of an inlet valve collet (the bit that holds spring down and valve up, may be called summink differant!) fell down an oilway
will it be ok?!?
it was the oilway above and just to the left of no4's inlet valve, the one about 10mm wide
i heard it make a noise at the bottom, was that it falling into the sump? if so shud it be ok, as the pick-up pipe has that gauze covering it
Old Jun 11, 2005 | 03:07 PM
James Raby's Avatar
James Raby
I wouldn't trust it
Old Jun 11, 2005 | 03:09 PM
andre_k's Avatar
andre_k
its been ok for 30 miles so far!
Old Jun 11, 2005 | 03:10 PM
SteveB's Avatar
SteveB
The amount of times i've taken a sump off a CVH and found collets in there ......lol
Old Jun 11, 2005 | 03:11 PM
James Raby's Avatar
James Raby
Well, it'll be alright on the night then PMSL
Old Jun 11, 2005 | 03:14 PM
Ginge !'s Avatar
Ginge !
just finding my feet
try removing the sump to take it out
i cant see how it would drop in the sump direct though
Old Jun 11, 2005 | 03:17 PM
tonysr's Avatar
tonysr
it wouldnt of made a noise if it fell into the sump of oil
Old Jun 11, 2005 | 03:20 PM
James Raby's Avatar
James Raby
GLUMP! - maybe lol
Old Jun 11, 2005 | 04:02 PM
Ginge !'s Avatar
Ginge !
unless ya got no oil in it
if it was my 7litre sump ya would hear a splash and they hear waves
Old Jun 11, 2005 | 04:16 PM
xr2fatturbo's Avatar
xr2fatturbo
aslong as its fallen to the bottom of the sump mate you wont have a problem ive done it myself!
Old Jun 11, 2005 | 04:19 PM
Lee Reynolds's Avatar
Lee Reynolds
lol i did that on my first s2 years ago. I left it in there and had no probs from it!
Old Jun 11, 2005 | 04:26 PM
Alvyn's Avatar
Alvyn
think about all the cossies etc that are running about with different lenghts of the dip stick(which have snapped off)floating around in the sump with no probs so UNLESS your very unlucky woundn't worry until have to take sump off
ps you could always drain the oil out and see if it comes out 1st time,and also try using a magnet to drag the collet out the sump plug hole
Old Jun 11, 2005 | 04:30 PM
alan rainbow's Avatar
alan rainbow
drian the oil and move collet with a magnet to get it out
Old Jun 11, 2005 | 04:33 PM
Rick's Avatar
Rick
wont do any harm. Noise u hear is it hitting bottom of sump.
Old Jun 11, 2005 | 04:34 PM
Neil S's Avatar
Neil S
The collets are magnetic so will simply attach themselves to the sump
Did it on the girlfriends fiesta and it was fine for about 10k till it got pinched!!
How bad is the feeling when you realise where it's going?
I wouldnt worry about it
Neil.
Old Jun 11, 2005 | 05:10 PM
rswoza's Avatar
rswoza
i did something very similar to this when the end of my dipstick snapped off, i used one of those snap on arial type magnets... a magnet on the end of a car arial which i poked into the sump via a the drain hole got it out after 2 mins
Old Jun 11, 2005 | 05:12 PM
Lee Reynolds
my old escos's dipstick end snapped off too
Old Jun 11, 2005 | 05:13 PM
Alvyn's Avatar
Alvyn
as I said above very common for that to happen
Old Jun 11, 2005 | 05:50 PM
morcheen's Avatar
morcheen
just get a magnetic sump plug,and it should stick to it ,in time,i don't think collets are magnetic.
Old Jun 11, 2005 | 06:13 PM
andre_k's Avatar
andre_k
Old Jun 11, 2005 | 06:33 PM
DazC's Avatar
DazC
As long as you fitted another collet to the valve so there is a pair of collets back on the valve then it won't be too much of a issue.
If you are only running one collet, expect the engine to drop a valve into the cylinder and destroy your engine.
Old Jun 11, 2005 | 07:21 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
What Daz said. Dont worry about the one in your sump. If you're removing the sump anyway, take it out, but otherwise...
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
