S2 boostin problem
Old Jun 9, 2005 | 10:36 PM
rsboy82's Avatar
rsboy82
Default S2 boostin problem
hiya my mates got a S2 escort turbs and hes been havin a problem with the boost hes put a boost gauge and wont run no higher than 0.2 bar
hes put a new turbo actuator unpluged the amal valve put on a bleed valve and still no difference he even round the bleed valve right down and still no difference
and it feels as fast a 1.1 fiesta crossflow
has anybody got any ideas please
cheers
Old Jun 9, 2005 | 10:41 PM
GrimmeRS2K's Avatar
GrimmeRS2K
the actuator he has put on is proberly set to low, give it a turn,then see what happens, also if the amal valve unplugged make sure u block the metering unit hose off
Old Jun 9, 2005 | 10:58 PM
rsboy82's Avatar
rsboy82
cheers dude wont the bleed valve over rite the acctuator or does it work independantly?
Old Jun 9, 2005 | 11:16 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u say u wound the bleed valve right down, it has to be wound out for more boost
i think the actuator has to have some force on the rod at least,cant just put it on, have to pull it over the wastegate with a bit of force
Old Jun 10, 2005 | 11:08 AM
rsboy82's Avatar
rsboy82
ok cool ill ask him to try his acctuator
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
