injectors...
Old Jun 9, 2005 | 11:44 AM
steven720's Avatar
steven720
Default injectors...
i'm just wondering will biege 701 injectors fit straight in or will i need to change the chip at the same time?
cheers
Old Jun 9, 2005 | 02:17 PM
sailorbob's Avatar
sailorbob
Chipping is required so the ecu knows the bigger injectors are there.
Old Jun 9, 2005 | 10:57 PM
bud-weis's Avatar
bud-weis
Football Cwazy
just so you know , the standard injectors are good for around 180bhp, so if you don't intend going higher than that your money would be better spent on the chip.
Old Jun 11, 2005 | 10:54 AM
steven720's Avatar
steven720
cheers guys, thanks very much
Old Jun 12, 2005 | 10:10 PM
ON-UJAH's Avatar
ON-UJAH
Also Beige injectors are much more expensive than the almost identical Corrado Greens.
Old Jun 12, 2005 | 10:22 PM
steven720's Avatar
steven720
which ones are better? beige or green?
Old Jun 17, 2005 | 08:09 PM
gavintwopies's Avatar
gavintwopies
Are these corrado green injectors a high or low impedence injector as i'm on the look out for some to run a 2.1 zt engine
primedog
Oct 29, 2014 09:16 PM
Smidydevil
44
Jul 4, 2013 01:20 PM
Rogeyboy
Nov 13, 2011 06:46 PM
Yogi.
Nov 4, 2009 06:47 PM
