Front wheel camber, please help
Hi All,
Got a wee bit of a camber problem on my front wheels to the point where my passenger side tyre was scrubbed down to the metal!!
its a V6 Mondy & its lowered by 40mm I know that lowering them can cause this but it just seems a bit severe. I was wondering if anyone knows of a way to adjust the suspension to combat this?? obviously I cant keep replacing tyres every couple of months, also just discovered my drive shaft (also pass side) is goosed, could the two be connected?? dont want to go to fraud coz they charge just to take a look at it.
Any advice is greatly appreciated
Debbie
its a V6 Mondy & its lowered by 40mm I know that lowering them can cause this but it just seems a bit severe. I was wondering if anyone knows of a way to adjust the suspension to combat this?? obviously I cant keep replacing tyres every couple of months, also just discovered my drive shaft (also pass side) is goosed, could the two be connected?? dont want to go to fraud coz they charge just to take a look at it. Any advice is greatly appreciated
Debbie
Its likely that your running to much negative camber, lowering it wont have helped, best bet is to find a specialist in 4 wheel alignment, they may be able to adjust camber so its not quite as bad.
Im unsure just how much adjustment there is on your car so you may or may not be able to cure the problem.
HTH
HTH
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
