IS A T25 TURBO GOING TO BE ANYGOOD FOR ME???
Old Jun 4, 2005 | 10:33 PM
gavintwopies's Avatar
gavintwopies
Default IS A T25 TURBO GOING TO BE ANYGOOD FOR ME???
AS ABOVE I'VE BEEN OFFERD A T25 TURBO OFF A FRIEND STILL IN ITS BOX IT WAS GOING TO BE GOING ON TO A SILVIA TURBO
THING IS ITS GOING RATHER CHEAP AND WAS THINKING IT MIGHT BE OF SOME USE TO ME
THE T3 EXHAUST HOUSING/ELBOW WILL TRANSFER STRAIGHT OVER ON TO IT MY ONLY CONCERN IS THAT I'M JUST ABOUT TO PUT A 2.1 ZVH IN AND WAS THINKING ON ONE HAND THAT IT MIGHT BE TO SMALL???
OR ON THE OTHER HAND THE FACT THAT THE QUICK SPIN UP OF THE TURBO MIGHT WORK VERY WELL WITH THE LOW DOWN TORQUE POWER THAT THE ZVH ENGINE PUT OUT WHAT DO YOU THINK?
KNOWING MY LUCK ITS GOING TO BE NO GOOD
Old Jun 5, 2005 | 07:41 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
nah if anything a T28, but they run out of puff in higher revs, i'd say it'd be useless mate.
Old Jun 5, 2005 | 08:02 AM
T28 RST's Avatar
T28 RST
Ok then
Im making my peak power at over 6000rpm on a T28, how high do you want it to rev
Old Jun 5, 2005 | 10:19 AM
radiant red's Avatar
radiant red
My mate uses a t25 on his fiesta rs and it is not very immpressive if you ask me, but then his car is a bit on the worn side. Give it a go mate, let us know how you go on
Old Jun 5, 2005 | 11:17 AM
Badman38's Avatar
Badman38
yeah but your cars 1600 on a 2.1zvh i think this turbo will be too small run out of puff early
Old Jun 5, 2005 | 11:41 AM
doggydowg's Avatar
doggydowg
dont zvhs run out of puff at 5.5-6k anyways surely itb be better having a small turbo to make use of the zvh,s lowerdown powerband? my t3 doesnt start pulling till 3.5k and if peak power is 5.5-6k thatd give you a 2.5-3k powerband;-( id rather have a small turbo for around town but i guess its what you want the car for balls out power/quartermile?
Old Jun 5, 2005 | 02:39 PM
gavintwopies
THATS MORE OR LESS WHAT I WAS THINKING I WANT IT FOR DRIVEABILITY NOT FLAT OUT POWER AS ITS GOING TO BE AN EVERY DAY DRIVER
I WAS THINKING OF PUTTING A T34 OFF ANOTHER M8S COSSY OR EVEN A STD COSSY T3 BUT EITHER ONE OF THEM WILL COST ME A BIT THIS T25 I'VE BEEN OFFERD IS GOING FOR 25 NOTES AS HTHE OWNER BEEN BAND FOR 2 YRS AND ITS SITTING IN HIS SITTING ROOM
BUT IF ITS GOING TO BE A WASTE OF TIME THEN I'M NOT THAT BOTHERD AS ITS NOT GOING TO COST A LOT. AND BESIDES I'M ONLY THINKING OF RUNNING 14 PSI ANYWAY EVEN ON THE 2.1
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
