Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
Flojet water injection pumps
Old Nov 12, 2003 | 01:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default Flojet water injection pumps
As used by many works rally teams and all the "best" cars (Martin Hadland, me etc ).
£125 delivered.
Old Nov 12, 2003 | 10:46 PM
xrsi's Avatar
xrsi
what else is needed to make a water injection?
Old Nov 13, 2003 | 12:05 AM
PJay's Avatar
PJay
I'd say wiring (relay, fuse, etc.) Water Hose, Water Jet and a controller of some sort depending on your chosen setup.
Someone will probably give you a better answer though.
PJay
Old Nov 13, 2003 | 07:40 AM
Mike Rainbird
Caraholic
Spot on, although you really want a properly mapped set up...
Old Nov 13, 2003 | 10:45 AM
xrsi's Avatar
xrsi
how much would i be looking for all this tho?
i have an frst and wanted the basic aquamist system.. the non mappable one! sdo want it to be the equivalant of this.. was seeing if it was cheaper this way!
Old Nov 13, 2003 | 11:07 AM
Mike Rainbird
Caraholic
The cheapest way would be the basic Aquamist system, BUT you would need to use this in conjunction with one of our ACT gauges (with the WI facility). This is because the Aquamist set up is flawed in that it only works off boost pressure. However, you want it to work of boost AND ACT. i.e. the water is ONLY injected into the engine if the boost is above (user set psi) AND the ACT is a above (user set temp). If you inject water into the system on a pressure only basis and the charge temp is not sufficient to absorb the water in the heat exchange process, it will lead to mis-fires and poor running.
Old Nov 13, 2003 | 11:10 AM
PJay's Avatar
PJay
Just out of interest is it bettert to run fully mapped or boost/temp switched e.g. WI comes on at ??PSI & ??DEG-C? as i heard of a few people that use a boost switch and there secs monitor to trigger there WI.
Many thanks
PJay
Old Nov 13, 2003 | 12:02 PM
Eagle's Avatar
Eagle
Super Moderator
so what temps are you looking at then??
Old Nov 13, 2003 | 03:40 PM
Mike Rainbird
Caraholic
ECU controlled is the best sort, with the charge temp / boost pressure a close second and the throw water in at a set pressure a bit of a hit and miss affair .
Old Nov 13, 2003 | 03:55 PM
Eagle's Avatar
Eagle
Super Moderator
ok.. so what ecu's support this then??
fookin feel like a dentist .. pullin the answers out...
Old Nov 17, 2003 | 09:16 PM
Mike Rainbird
Caraholic
Pete,
All you need to know is that yours does... .
Old Nov 17, 2003 | 09:35 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
mike pm me a pic please
Old Nov 17, 2003 | 09:48 PM
Eagle's Avatar
Eagle
Super Moderator
Pete,
ok... so how easy is it to do ...would it be easier to just get an aquamist system ... gonna run in conjunction with my rs500 intercooler..
Old Nov 18, 2003 | 11:24 AM
Mike Rainbird
Caraholic
Pete,
Forget it, on 803s and your turbo, you aint EVER gonna need WI with that intercooler .
However, when you do get a big boy's engine, then keep it all controlled by the ECU.
All you need then is:
Reservoir (although you can connect to your windscreen washer tank, using the redundant headlight pump to prime the Flojet),
Relay to switch pump on/off,
Tubing,
One way valve,
Filter,
Jet,
Flojet pump (which will sit nicely behind nearside headlight).
Cheap as chips!
Old Nov 18, 2003 | 11:25 AM
Mike Rainbird
Caraholic
PS. Why don't you purchase a nice ACT gauge to see if you need WI...
Old Nov 18, 2003 | 11:40 AM
Eagle's Avatar
Eagle
Super Moderator
what like the one i got from you 2 months ago
Old Nov 18, 2003 | 11:44 AM
Mike Rainbird
Caraholic
So why the fuck don't you use it then ?!
Old Nov 18, 2003 | 11:54 AM
Eagle's Avatar
Eagle
Super Moderator
i am you norfolk inbred
Old Nov 18, 2003 | 12:00 PM
Mike Rainbird
Caraholic
So you WILL know that WI is not required when you fit the RS500 intercooler .
If you need the hoses or drop bracket to fit this, then I can help, you Reyland wannabe )...
Old Nov 18, 2003 | 12:13 PM
Eagle's Avatar
Eagle
Super Moderator
actually i do need the hoses...whats a drop bracket for???and when i get my new turbo am i gonna have probs then??? eh ??eh ???
Old Nov 18, 2003 | 02:55 PM
Mike Rainbird
Caraholic
If you fit the RS500 hoses, the extra girth (oh er ) catches on the blades of the alternator and so this has to be dropped down on an RS500 bracket (£50 delivered). However, you have to grind a piece off the side of the block to allow the bracket to fit (if you look underneath where the alternator currently bolts to, you will see).
Alternatively, you could chop the ends of the 500 cooler off (remembering to keep hold of them in case of future requirements) and the ones off your 4x4 one to weld these to the 500 item (or better still, buy a £30 2wd item to do this to, as a 4x4 one is worth £80-100). This negates having to spend £150 for the RS500 boost hose kit and the £50 for the drop bracket (as well as having to chop 1" lengths off you old hoses to sleave down the insides of the 500 hoses to fit on the turbo and throttle body). If you did ever get a T4, you could reverse the process.
The choice they say, is yours... .
Old Nov 18, 2003 | 08:50 PM
xrsi's Avatar
xrsi
right any idea where i would get the jet etc from?
also how much is one of your act gauges with WI function!!
Old Nov 18, 2003 | 09:32 PM
Eagle's Avatar
Eagle
Super Moderator
im sure you can get the hoses in a reduced size to fit on a standard turbo... im going for a t 34/5 or what ever they are...want a .63 i have been told its the better bet .. but this wont happen untill i get the funds... unless you do easy payment plans
Old Nov 19, 2003 | 07:26 AM
Mike Rainbird
Caraholic
XR,
ERL for the jet - £9 each.
£65 for the ACT with the WI feature.
Pete,
Good luck if that is what you think...
Old Nov 19, 2003 | 10:36 AM
xrsi's Avatar
xrsi
would a normal relay work with this??
washer jets pipe would work aswell wouldnt it for the water pipe....
seriously thinking now
also whee wopuld ay get a wiring diagram to wire it all in from?
Old Nov 19, 2003 | 10:59 AM
Mike Rainbird
Caraholic
XR,
Would a normal relay work with what?
Yes.
Wiring diagram for what?
Old Nov 19, 2003 | 04:46 PM
Eagle's Avatar
Eagle
Super Moderator
Pete,
erm i dont...just going by what i have been told...oh fook it im gonna have to ring you and talk to you now....
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
