Standard ERST fan switch, what temps should it cut in &
Old Jun 1, 2005 | 09:45 AM
zvhturbo's Avatar
zvhturbo
Default Standard ERST fan switch, what temps should it cut in &
Standard ERST fan switch, what temps should it cut in & out?
Does anyone know, i think mine is buggered, it cuts in at 100degrees
Old Jun 1, 2005 | 10:14 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
92 I think mate
Stat opens at 88, fan at 92 I believe
Old Jun 1, 2005 | 10:24 AM
zvhturbo's Avatar
zvhturbo
Hmmm,
I've stuck an 82 degree stat in for now with a cozy fan switch.
Matt
Old Jun 1, 2005 | 10:47 AM
MikeyXR2i's Avatar
MikeyXR2i
Anyone got the older type ERST Fan switch off an S1? its the brown one with the Spade type connectors.
Old Jun 1, 2005 | 03:48 PM
Tony Turbo's Avatar
Tony Turbo
Originally Posted by zvhturbo
Hmmm,
I use an 82 degree stat too
Old Jun 1, 2005 | 04:33 PM
zvhturbo's Avatar
zvhturbo
Hmmm,
What fan switch do you use??
Old Jun 1, 2005 | 05:13 PM
rs_daz's Avatar
rs_daz
cossie fan switch 7001614 red
I got the state too 82 one.. temp never goes over half way now
Old Jun 1, 2005 | 05:47 PM
tonyturbo's Avatar
tonyturbo
would this stat fit a zetec? if not which 1 do i need?
Old Jun 1, 2005 | 06:12 PM
Tony Turbo's Avatar
Tony Turbo
I don't. My ECU controls the temperature the fans come in
Old Jun 1, 2005 | 10:59 PM
PPSSSHH's Avatar
PPSSSHH
i used to have loads of 52mm gauges in me grey turbo one of wich was a revotech water temp and according to that it used to hit 60 degrees and the fan would come on every time but im told that some after market gauges can be incorect due to some univesal parts
Old Jun 25, 2005 | 10:37 AM
Andrew's Avatar
Andrew
Sorry people, i've just been looking for a post liek this, where abouts have you guys got your cossie fan switches from?
Old Jun 25, 2005 | 05:19 PM
RS-adam's Avatar
RS-adam
mine also didn't get over half way, wit the 82 stat and cossie fan switch, but then I put my bumber back on... and know it get over half way some times.... so im cinsidering cuttin out my bumber
Old Jun 25, 2005 | 06:25 PM
Rs_Dave's Avatar
Rs_Dave
iv just fitted a 82 degree stat,, its made no difference, to b honest its made it worse!
so were do u get the cossie fan switch from??
manuel boeckx
13
Oct 3, 2015 02:29 PM
Bailes1992
Sep 3, 2015 02:17 PM
Vacuman
16
Sep 3, 2015 06:26 AM
gchristophi
Aug 31, 2015 10:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
