1988 F Reg ERST wont idle at all, please help me
Old May 26, 2005 | 04:48 PM
1992FRST's Avatar
1992FRST
Default 1988 F Reg ERST wont idle at all, please help me
basically the engine is very healthy, just been set up at power engineering 2 weeks ago, shes running 176bhp.
mods are, Exhaust, air filter, Power engineering Chipped it when setting it up, bleed valve ( i never touch the bleed).
was fine for the past 2 weeks, but now wont idle at all, i have to keep the revs up myself, the car pops and bangs out the exhaust a bit more than normal aswell.
litterally if ur coming up to some traffic lights or anything or u brake and the revs drop she stalls, sometimes she starts again , but others she wont start for like 1 min
does anyone have any ideas, as the car is pissing me off to the extent that i want to sledge hammer it, ive decided to sell it for sure now, just want her fixed and running mint again as she was
Old May 26, 2005 | 04:53 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
sounds like a fuel starvation problem,maybe your pump is on its way
Old May 26, 2005 | 04:56 PM
GrimmeRS2K's Avatar
GrimmeRS2K
running a dumpvalve?
Old May 26, 2005 | 05:24 PM
1992FRST's Avatar
1992FRST
no mate, no dv either, i hope its not the fuel pump
Old May 26, 2005 | 05:31 PM
GrimmeRS2K's Avatar
GrimmeRS2K
also could be a dizzy problem, mine popped and banged and died now and again and would start, try the pump as mentioned aswell
also check all the breather pipes are on ok, also the boost ones while ur at it!
or the fuel pump relay, pink one under the dash, could have an intermittent fault
Old May 26, 2005 | 09:47 PM
MikeyXR2i's Avatar
MikeyXR2i
Also check the Pipe going to ya Brake Servo, if its split or leaking she won't run.
Old May 27, 2005 | 08:42 AM
tony:mac's Avatar
tony:mac
Check for any air leaks, after a recent rolling road on my S1, the brake servo pipe worked loose and the car was almost impossible to start and when it did it died on tickover - I thought `hang on it`s not supposed to be like this` AFTER a rolling road, then we noticed the loose pipe, tightened it up and hey presto!!
Check for any loose pipes, tighten your jubilee clips on all the pipes etc.
Old May 27, 2005 | 09:49 AM
l5tuy's Avatar
l5tuy
Check all the air pipes, turbo's hate un-metered air, it messes with there brain.
I recently had the same prob, irratik idle mostly at 300 revs then dying, everyone said air leek and after messing around for a month couldn't find any leaks. Then last weekend was changing the valve steam seals and noticed the rocker cover gasket had a chunk missing, whala problem solved.
Moral of story, turbo's hate un-metered air.
Old May 27, 2005 | 01:56 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
l5tuy, Where in scotland you from mate?
1992FRST, check the idle speed control valve located under inlet plenum (bolted to it) i forget the proper name for it now
Old May 27, 2005 | 02:39 PM
1992FRST's Avatar
1992FRST
thanks alot for all ur help guys, its most appreciated
vrrrooooom ptiiishhh : - wheres the inlet plenum and the Idle Valve ?
tony:mac : - i know what u mean mate, i spent Ł400 on her and expected it to last a little while after the rolling road
i will check the Idle control valve + all the pipes etc tonight once it cools down outside
Old May 27, 2005 | 02:59 PM
vroooom ptssssh
It Wasnt Me!
The idle speed valve (thats what it does but not the proper name) its the bit with the black pipe going into it on the right with the oxodised bit of metal with no pipe connected!
Old May 28, 2005 | 08:15 AM
L33 BYT's Avatar
L33 BYT
The Aux air device. Should be black multiplug. Try disconnecting this temp see if this helps. If it does then.
A) Take this device off and clean with brake cleaner inside. then squirt with WD40.
B) The earth for this is on the wiper motor bracket. check connected and clean.
Check things like oil dipstick in place correctly and Oil filler cap sealed.
Also the vacuum pipes.
Old May 28, 2005 | 06:30 PM
1992FRST's Avatar
1992FRST
right, just an update,
Ive now checked the Pipes, Idle Control valve, they are both ok, i disconnected it, the same prob persisted when i started it revs die instantly.
who thinks this could be a Fuel Pump Problem? its just this car drives spot on going down the A3 , ive done 500 miles now with the car like this, nothing wrong with the cars top end speed or acceleration.
just pops and bangs out the exhaust a bit more than normal.
thanks for the help guys
Old May 28, 2005 | 08:04 PM
akito-man's Avatar
akito-man
the reason i say the pump,is that when driving along,the pump is flowing quite freely,pluss the vac pipe to the tank will give some pressure,to boost fuel flow,if your pump is on its way out,the impeller could be slipping causing erratic fuel flow whilst under little pressure is supporting the feed,like mine done,
BUT HEY! (in an american/bronx/italian/goodfellas accent)
"im juss a fookin painta,who doesnt give a shyit!" " know warra mean?"
Old May 29, 2005 | 10:23 AM
LittleMissFordie's Avatar
LittleMissFordie
I was going to say the same. I had my dump valve fitted against all advice and I think because the car had never been touched its whole life it basically rejected it,
Old May 29, 2005 | 10:44 AM
l5tuy's Avatar
l5tuy
vrrrooooom ptiiishhh:- I'm from aberdeen, what about you. Is that your series 1 in the sig
Old May 29, 2005 | 10:47 AM
LittleMissFordie
Its a series 2 actually
Yes its mine
Old May 29, 2005 | 10:53 AM
akito-man's Avatar
akito-man
potash,thats not you sig!
Old May 29, 2005 | 11:15 AM
l5tuy's Avatar
l5tuy
Julia, i wasn't meaning your sig, i was speaking to vrrrooooom ptiiishhh.
Are you out alot in Aberdeen, driving or clubbing.
Old May 29, 2005 | 11:20 AM
akito-man's Avatar
akito-man
er hello!
Old May 29, 2005 | 11:22 AM
l5tuy's Avatar
l5tuy
like en!!!
Old May 29, 2005 | 11:23 AM
akito-man's Avatar
akito-man
fifeingtons
Old May 29, 2005 | 05:46 PM
LittleMissFordie
If I go out I normally go to Blu Bar, Ministry or Liquid, what do u drive then
Old May 29, 2005 | 08:17 PM
l5tuy's Avatar
l5tuy
I have a series 1, was at the rsoc show at the xehibition centre with it
Old May 29, 2005 | 09:42 PM
akito-man's Avatar
akito-man
our kid had your name as his reg,gen mate!on his 4x4!
Old May 30, 2005 | 03:59 PM
vroooom ptssssh
It Wasnt Me!
l5tuy, Yup thats my series 1 mate, im from Glasgow
Old May 30, 2005 | 07:31 PM
l5tuy's Avatar
l5tuy
na, im sure its mine like, its my name on the documents, i think.
only foolen seriously did you own it befor Ron
Old May 30, 2005 | 09:01 PM
akito-man's Avatar
akito-man
stand corrected,4x4 sierra,a5tuy!
Old May 31, 2005 | 02:07 PM
an1mal_69's Avatar
an1mal_69
sounds deffo like an air leak, mine used to have a dodgy dip-stick seal (was actually a bit of insulation tape.. ), but anyway, when up on high boost, it used to push the dipstick up a little opening the seal and causing the exact same problem, sounds great to drive, popping and bangin everywhere, but as soon as you get to a junction you look a tw*t as it conks out on you...so if you aint alrady, check the dipstick is nice an tight..filler cap has a good seal, and the rest of the breather system, pipe from the rocker down to back & the flame arrestor on the left (cam belt side)
Old Jun 3, 2005 | 03:16 PM
1992FRST's Avatar
1992FRST
the dipstick thing seems ok, always nice and tight,
Another thing ive noticed is , Fuel Econemy is getting WORSE and WORSE so i normally get 25MPG, its slowly going down and down.
its now down to 15MPG!!!!! which is killing me, im doing 500miles a week now and im spending ALOT of cash lol
Old Jun 3, 2005 | 04:49 PM
GrimmeRS2K's Avatar
GrimmeRS2K
could be a fuel pump problem then mate, or the relay, or the fuel ecu, all worth checking, and replacing your fuel pump is always a good idea, because this is a major factor why so many rst's blow up, coz the fuel pump is tried, it may seem ok, but a test can prove its tried, mine had the problem, i thought it was fine, but APT tested it and it wasnt flowing smooth!
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Fil
Sep 30, 2015 12:08 PM
