Cabriolets/MX5 turbos
Im toying with the idea of some roof off fun and have quite taken a liking to the mx5 turbos, cheap and cheerful rear wheel drive fun?
Or can anyone suggest other alternatives?
You can get import Eunos with turbos, there are 3 on autotrader
220bhp in one of those must be fast as fook!
1990 MAZDA MX-5 1.6i Turbo ,
H reg. 72000 miles, Turbo charged Eunos Roadster (220) bhp, BRG, tan leather, new racing clutch, new hood, tax and tested, a/c, e/w, 16alloys, and loads more toys, fsh last 4 years, very fast car. £3,995
They never made an MX5 turbo but as the engine from the mx5 is the same as a 323 you can bolt a turbo or supercharged on them and run 15psi 1 bar straight away with no internal engine mods (apart from fuel intercoolers etc), I have heard you can run even more with the auto engine as they are even lower comp! Hence why there are loads of kits both turbo and supercharged out there.
I had a greddy turbo on mine with a bipes ecu running 12psi with little 14inch wheels and it was the best car I have had to drive. Anymore boost though and the clutch would slip, and the rear diff is only a 6.5inch so my lsd turned into an open diff!
JK12
33
Apr 26, 2021 12:09 PM
