General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I need to replace mine, are they better then the standard ford item ie: are they less prone to leaks, and do you still use the standard half moons with it.
Whats wrong with the normal type of cam cover gasket Spadge?
The Cometic ones are re-usable, seal better and don't fall to pieces and weld themselves to the head when you remove the cam cover like those paper things
