Oil Consumption
Old May 20, 2005 | 11:09 PM
Mr.Ford's Avatar
Mr.Ford
Default Oil Consumption
Hey People,
My cossie 4x4 uses +- 0,8 Litre Oil on +- 620 Miles
Is that normal??? If not, what could be wrong?
Would it be possible that my turbo is worn?? The car smokes a bit wen I let the accelerator loose (after I give a max. turbo-boost)
The spec's:
- 803 greens
- 3 bar map.
- Motorsport sparkplugs
- Motorsport powercables
- K&N 57i GR A
- T03 Garret (original) Peak boost 22 PSI con. 19 PSI
- Garret -31
- Mongoose 3"
- Collins Chip
- Forge Breatherkit
- Bailey Headertank & Swirlpot
- Gr. A Gasket
- ARP Stud & Nuts
- Nomad Racing Dumpvalve
Please give me some advice! Thnx
Old May 21, 2005 | 09:17 AM
daz1968's Avatar
daz1968
Sounds normal to me, mine uses a bit more than that
Old May 21, 2005 | 10:28 AM
snow*'s Avatar
snow*
Yea, my Sapph is a greedy oil monster too.
Similar specs to you Mr.Ford and uses a touch less than your does.
I also get the smoke when I put my foot down hard
Old May 21, 2005 | 12:43 PM
john_p_b's Avatar
john_p_b
i've concluded 1 thing in the last few months sinse owning mine, the only way to get a cossie not to use oil is not to drive the damn thing! anyone who says they don't have to top the oil up ever is lying!
Old May 21, 2005 | 06:16 PM
tkrath's Avatar
tkrath
My Sierra Cosworth 4x4 (with MSD 330kit) uses about 2,5 litre on 6,000 miles/10,000 km. Your car should use some oil and I believe Ford says up to 1 litre every 600 mile/1,000 km is okay.
However, there should not be any blue smoke from the car!!
Old May 22, 2005 | 09:57 AM
Mr.Ford's Avatar
Mr.Ford
You're right about what ford says...but
IF a car does use a bit oil, is has to smoke!
Because, how else did it looses his oil???
I think it's rather much, but if all the cossie-drivers have got the same useage then it will be normal I think
Old May 22, 2005 | 10:12 AM
john_p_b's Avatar
john_p_b
Mr.Ford is bang on there! if it's going to burn even the slightest bit of oil it's going to smoke to some extent. surely if ford say 1 litre to every 600 miles is acceptable on a standard engine then surely you should allow a little more for a engine running higher boost pressures etc?
either way until it's getting to a point where you are having to stop every 15 miles to top up just keep driving it
Old May 22, 2005 | 03:43 PM
Mr.Ford's Avatar
Mr.Ford
If you always have to put some oil in the engine, at the same time when you're going to refuel your petrol tank, then it's not funny
Old May 22, 2005 | 04:53 PM
wimwerf's Avatar
wimwerf
no...its not normal.....its on the limit what it should use max on oil per 1000km...
somethings worn.....
Old May 22, 2005 | 05:04 PM
r5jame5's Avatar
r5jame5
mine is a band new rebuilt engine running around 400 bhp built by harvey gibbs it uses a little more than mr fords .
Old May 23, 2005 | 07:18 PM
Ian M's Avatar
Ian M
in that case i would be taking it back because mine uses very little between oil changes.
Old May 23, 2005 | 09:59 PM
Mr.Ford's Avatar
Mr.Ford
so I still don't know a thing...everyone says something else
What's a normal Oil Consumption???
Old May 23, 2005 | 11:00 PM
2001ode's Avatar
2001ode
Hi,
Normal oil consumption is, maxi, 1 gramme by 1 hp by 1 hour.
Approximat. 1 % of fuel consumption, I think.
Regards
Old May 23, 2005 | 11:38 PM
cossiedaz's Avatar
cossiedaz
mine uses 1 litre every 300 hundred miles and it chuffs blue on vacuum overrun (backoff), ive been told that this is either turbo or valves guides being completely knackered, as i had the turbo rebuilt 3 thou ago it seems likely that my problem is valves guides, will report more as soon as ive had em fixed.
Old May 24, 2005 | 05:55 AM
wimwerf's Avatar
wimwerf
max oil the engine use per 1000km is 1 litre....anything more oil is not good...anyhting less is better...
Old May 24, 2005 | 08:48 AM
Mr.Ford's Avatar
Mr.Ford
mine is less, it uses +- 0,8 litre per 1000km (sometimes its about 0,6-0,7)
But, I don't like the blue smoke (although it's not very much)
Old May 24, 2005 | 01:05 PM
The Gravedigger's Avatar
The Gravedigger
Mine uses way more and it doesn't smoke noticeably??
Old May 24, 2005 | 11:26 PM
Mr.Ford's Avatar
Mr.Ford
mmm. that's strange...
Did you already have some one that watched from the outside of the car when you give full trottle?
If your cossie uses Oil ,then it has to smoke (a little at least)
Old May 25, 2005 | 08:31 PM
plater's Avatar
plater
Not true, lost oil doesn't necessarily have to be burning off and causing smoking, if the ford breather system is struggling under full boost then it could just as easily be getting forced out through worn seals at the crank pulley or the camshaft seals, up through the distributor or blown into the air filter box. If the engine is overly wet or dirty underneath or particularly at the front behind the cam-cover, then this is where most of the lost oil is going
Old May 26, 2005 | 08:43 PM
TurboFlush's Avatar
TurboFlush
Oil consumption on Turbo built cars is normall. they are often built with a looseer ring gap. Diesels do the same. It just depends on how it is built!
I rather mine use a little oil every 600km then to have stuff break because it is to tight when it gets warm.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
