fitting konis to a 3 door cossie
You need to remove the 6 beam bolts,rear shock, and roll bar connection to arm, and if i remember rightly the arm should then go low enough to remove the spring. Might have to unbolt driveshaft, cant remember. Not as difficult as it sounds.
If you'e got small enough spring clamps you can get em round the spring to compress it with just the shock removed.
It works on a saff 4x4 so I would assume you can do it on a 3 door aswell
jessie_rs
11
Jun 3, 2019 04:57 PM
COSWORLD
Aug 14, 2015 07:40 AM
track.focus'd
Aug 12, 2015 05:53 PM
