Misfire under load - Doin my head in!!!
Old May 17, 2005 | 12:51 AM
gary scott's Avatar
gary scott
Default Misfire under load - Doin my head in!!!
Right im running a 1.8ZVH and ive got a misfire but only when my foot is flat to the floor!
If I hold the car at half throttle say then the mis-fire is still there but no where near as bad and it seems to ref fine.
The misfire is from about 4.5K upwards. Ive already changed the plugs, leads, cap, rotor arm. Tried 3 different fuel pumps (All known to be good) and even run another power feed to the pump just to be sure aswell.
Im only running 14psi and ive got a GRS cooler aswell. The engine has good compression on all cylinders aswell.
I have recently changed the wiring loom in the car as the one previous was a little tired but could the new one be causing the problem?
Was possibly thinking it could be related to the throttle switch maybe??? Anyone else have any ideas?
Getting desperate and dont really have the funds at the moment to take it anywhere!!
So come on people give me some ideas or stuff to look at/check
Thanks in advance
Gary
Old May 17, 2005 | 09:57 AM
AKRS1's Avatar
AKRS1
I had this problem with my cvh but it was misfiring at 5k and it turned out to be valve springs. But yours sounds like a management problem
Old May 17, 2005 | 01:44 PM
gary scott's Avatar
gary scott
Come on lads any other ideas???
Old May 17, 2005 | 04:05 PM
Wazzzer's Avatar
Wazzzer
cam, was on mine...
Old May 19, 2005 | 10:48 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Worth checking the TPS, but Cam/Lifters are a possibility too. What cam is it?
Old May 19, 2005 | 03:19 PM
gary scott's Avatar
gary scott
The cam is a 285T2 and its only done about 1000miles. It came in a kit and I used the springs and followers aswell.
Could the cam timing cause this? Ive renewed the cambelt recently and redialed the cam back in using the timing disc??
It still runs the same at idle and off boost just thinking this may be a possibility??
Old May 19, 2005 | 10:38 PM
radiant red's Avatar
radiant red
Mising under load can often be ignition prob, usally ht's or plugs, and the occasional coil pack. if you have one that is.
Old May 20, 2005 | 12:25 PM
chummer's Avatar
chummer
i had the same problem changed ht leads , cap , rotor arm , ecu! still the same! changed the dizzy and it was sound , see if u can borrow 1 it's worth a try
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
