changing brake fluid on a fourbie saph
Old May 16, 2005 | 08:06 PM
slowpoke's Avatar
slowpoke
Default changing brake fluid on a fourbie saph
whats the best way to totally change the brake fluid ???
also whats the best fluid you can get for mostly road use and the occasional track day each year ?
cheers...............matt
Old May 16, 2005 | 08:16 PM
dave cos4x4's Avatar
dave cos4x4
Hi Matt.
Don't get any brake fluid less than Dot 5, the minimum in a cossie, could get synthetic stuff but i don't think its worth the money and you have to change it more iirc.
Bit awkward to do on the cossie,you need a manual if you not done it before as you have to let the pump build up the pressure etc.. in the master cylinder.
better getting someone to do it who has ramps.
See ya soon Matt.
Dave.
Old May 16, 2005 | 10:43 PM
Neil S's Avatar
Neil S
Castrol SRF is the gear you want. Mike R does it for a very good price
Bleeding is relatively straightforward if you follow the manual step-by-step
Neil.
Old May 16, 2005 | 10:49 PM
SS1's Avatar
SS1
isnt there a kit you can get to do the brakes by yourself
i remember having probs bleeding my old rs2 ..tried doing it on axel stands
on the back
the car needs to sit flat ??? to do it properly
something to do with a brake compensator
Old May 16, 2005 | 11:54 PM
richm's Avatar
richm
cossies are easy to bleed, especially the back as it uses the ABS pump to pressurise fluid to the back and it self-bleeds when you open the bleed nipple. Turn the ignition on to run the ABS pump and wedge the brake pedal on slightly - this pressurises the back system. Fronts are bled by conventional pedal pumping method, or 'easibleed' system that pressurises the reservoir.
Old May 17, 2005 | 01:03 AM
Azrael's Avatar
Azrael
Castrol SRF is competition grade fluid and it's DOT-4 so Dot number isn't that great. Also road car fluids are DOT-5.1 not DOT-5
Old May 17, 2005 | 07:25 AM
Sticky.'s Avatar
Sticky.
Take it to Fords Matt, they do a full fluid change for £27. Saves the hassle if you break the nipples off, Ford will cahnge them.
Speak to you in a bit dude.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
hopper350
Sep 4, 2015 12:53 AM
