Bag of spanners CVH
Old May 15, 2005 | 04:58 PM
Escy's Avatar
Escy
Default Bag of spanners CVH
just got my old mans Mk3 Escort 1.6CVH carbed motor running for the 1st time since we had it. the engine is now starting easily. it idles at 500rpm, sounds lumpy as fook, even when you rev it.
somethings not good on it. you put your foot down on the accelerator and it doesn't pick up for ages and its not revving cleanly.
i'm just after some basic things to check. for a start, it has really old petrol in, that doesn't help. i slackened off the dizzy and moved it around a bit, it made no difference to engine revs. took the dizzy cap off and cleaned up that and the rotor arm.
i'm thinking the super low idle has something to do with the problem.
the head was supposidly rebuilt before we got it. i think the timing is wrong. can you adjust the tappets? if so, whats the cleances?
any ideas welcome. i'm well chuffed now its running.
Tom.
Old May 15, 2005 | 05:11 PM
Brookesy's Avatar
Brookesy
Tappets are hydraulic mate so cant adjust them. Adjust the tickover on the carb then see what its like when it warms up, timing could be out dont forget its been stood for a year and the oil needs to circulate back round the engine
Old May 15, 2005 | 05:13 PM
Escy's Avatar
Escy
can you tell me where on the carb is the idle control screw?
i've checked the plugs, they seem fine
Old May 15, 2005 | 05:17 PM
Zetec Andy's Avatar
Zetec Andy
if its the same as my old 1.8 CVH then its just under the air filter, shove your hand down under the filter and between the throttle cable, you should just be able to see it.
Old May 15, 2005 | 05:22 PM
Brookesy's Avatar
Brookesy
What carbs on your escort???
Old May 15, 2005 | 05:24 PM
L33 BYT's Avatar
L33 BYT
Dont assume here mate.
If in Doubt get plugs/Rotor/Leads/Cap. For what they cost you can then be SURE THESE are 100%
Old May 15, 2005 | 05:28 PM
Brookesy's Avatar
Brookesy
Lees got a point there might want to get a new fuel filter aswell. Dont forget when petrols been stood for over 2 months it seperates
Old May 15, 2005 | 06:54 PM
Escy's Avatar
Escy
just had the rocker cover off. there is a slight build up of cream on it, and also in the breather pipes.
i assume the headgasket has gone? or could that be from where its been sitting?
Old May 15, 2005 | 07:30 PM
st3v3's Avatar
st3v3
that could be condensation from the car just sitting around,it may take an hour or two to start clearing itself out,
Old May 15, 2005 | 07:57 PM
Escy's Avatar
Escy
yeah, was kind of hopeing thats what it was. i've noticed its only running on 3 cylinders which solves the shite running i think.
mk3ste
Oct 17, 2021 10:09 AM
sridgett
13
Sep 27, 2015 06:03 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
