FAO: RST'S RUNNING FOCUS ST170 FRONT BRAKES
EVENING
I WANT TO RUN BRAIDED HOSES AS I HAVE THEM ON THE BACK, I KNOW I COULD USE THE STANDARDS BUT WANT TO GO BRAIDED. CAN I USE THE REPLACEMENT GOODRICH ONES FOR RST? SOME PEOPLE SAY SHOULD BE FINE OTHERS SAY THEY WONT FIT IN THE CALIPER, WHAT BRAIDED HOSES DOES EVERYONE RUN?
NEED TO ORDER A SET ASAP.
CHEERS
CHEERS
I am led to beleive that you can't use ordinary braided lines with the ST170 conversion as they are a smidgeon too short. I think, but don't quote me, that Mike R sorted a set of correctly lengthed items for somebody.
how mong do you want them i can send u some out in morning
Talking of brakes Adam how are they?
is there a guide anywhere on exactly how to fit them on an s2? i got the whole kit pads, discs, and calipers and aeroquip braided lines. Cany anyone help?
cheeRS peeps
cheeRS peeps
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
hmmm, ok will probably get them drilled out then, and do i need to use st170 bigger bolts then?
suppose thats something for me to get then today from uncle henry's, lol
cheeRS
cheeRS
Couldn't be easier to fit really....get a drill with a 12mm drill bit and drill all 4 holes out. Go to your local hardware store (look in the Yellow pages if your not sure) and buy 4 M12 bolts then cut down to length. Put the disk on the hub......place the caliper of the disc (including pads) feed the bolt from the back of the hub through the spacer and into the caliper (ensure the bolts aren't too long that they foul on the disc). Connect the hose...bleed and your away
Palethorpe01
15
18-08-2015 06:09 AM
