Timeing adjusting itself....HELP
Old May 14, 2005 | 01:11 PM
Mr.h.'s Avatar
Mr.h.
Default Timeing adjusting itself....HELP
I took my car down to "MAD FOR IT" this morning to try and get her running properly but something is telling the ECU to adjust the timing which is throwing it way out???
Different ECUs where tried, also dif Dizzy but still the same prob???
Anyone had this prob or know how to sort it???
Nick
Old May 14, 2005 | 04:17 PM
GrimmeRS2K's Avatar
GrimmeRS2K
the vacuum pipe from the ecu is ok int it, not crushed by the heater box, or leaking?
Old May 14, 2005 | 06:40 PM
Mr.h.'s Avatar
Mr.h.
Colin from "mad for it" is sure its an electrical fault of some sort
What does the vacuum pipe do? What kind of effect would it have if it where crushed or leaking?
Also the coil has been moved from its normal position, its screwed/bolted by the bk of the meatering unit,could it make a difference being there?
Im no mechanic just a hairy arsed roofer
Nick
Old May 15, 2005 | 10:07 PM
davidreader5's Avatar
davidreader5
HI,
As above check the vacuum pipe from the manifold to ecu is not obstructed
a check for the ecu timing is blow down the pipe and with a strobe light
the timing should retard, and if you suck on the pipe the timing should advance.
Dave R.
Old May 17, 2005 | 10:29 PM
Mr.h.'s Avatar
Mr.h.
Thanks for the replies chaps
Originally Posted by davidreader5
HI,
Dave R.
What will this tell me then???
What part is at fault???
Sorry im just a roofer i aint a mechanic or very clued up about this sort of thing
Nick
Old May 17, 2005 | 11:19 PM
davidreader5
mrh,
it will tell if the ecu is at fault, the silver one out of the 2,
DAVE R.
Old May 18, 2005 | 11:50 AM
Rick's Avatar
Rick
knock sensor. very common.
Old May 18, 2005 | 10:58 PM
Mr.h.'s Avatar
Mr.h.
Tried a new " Knock Sensor" but still the same prob
Old May 19, 2005 | 04:55 PM
davidreader5
Hi,
Have you tried another ECU. JUST seen you have tried already
Doesent make sense as if you have tried all above should have the fault
sorted. how much in degrees is the timing altering.at a stable revs.
Dave R.
Old May 19, 2005 | 05:31 PM
Mr.h.'s Avatar
Mr.h.
Hi,
Dave R.
To be honest mate i havent got a clue how many degrees its altering
Ive had the timeing done 3 times within in 2 weeks now and after a while say 1 day it just goes shite again! I took the car to "mad for it" tried diff ecus, dizzies,knock sensor but its still the same? Could a broken wire mess it up?
I really want to get her running properly so i can just drive cos at the mo i cant get about cos i was told not to go driving her hard incase it goes "POP"
nick
Old May 19, 2005 | 10:14 PM
davidreader5
HI,
In theory if you set the satic timing(engine not running to the engine casing
marks approx 12deg, btdc, AND the rotor arm is pointing to no1 in the distributor position, then the ECU RUNS it from there, the dissy has a
in lay mans terms a switch inside it for a signal to the ecu so with the vacuum pipe
connected to the ECU AND inlet manifold the ecu knows what load is on the engine,
as we have said earlier about the vacuum pipe not being kinked or squashed
before it connects to the ecu, pull the pipe off the inlet manifold stub and blow
down it to see if it is clear remove it off ecu watch you dont snap the union
on the ecu, if all seems good at that end, check with the same pipe back on the manifold and try and blow into the manifold,COULD be partly blocked inside the
manifold causing a varied reading to the ECU load, also check the stub is sercurer on the manifold, Cant think of anything else
as all faults seem covered,
DAVE R.
Old May 21, 2005 | 09:25 AM
Rick's Avatar
Rick
make sure the knock sensor plug isnt shorting out
Old Jun 22, 2005 | 11:20 AM
Mr.h.'s Avatar
Mr.h.
Which sensor is that then? where abouts is it and what colour should it be?
NIck
Old Jun 22, 2005 | 05:57 PM
Mr.h.'s Avatar
Mr.h.
Up ya go
jessie_rs
11
Jun 3, 2019 04:57 PM
YODI
Aug 30, 2015 01:12 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
dal3door
Aug 13, 2015 06:55 AM
