Opinions please!!!
Im haveing a new engine fitted to my cossie.
So what do people think my bhp and torque figure will be when set up??
SPEC OF ENGINE AS FOLLOWS;
200 block +0.5mm bore
mahle pistons with big valve cut outs, 7.6-1 CR
knife edged, lightened and balanced crank
cometic multilayer head gasket
BD14 inlet and exhaust cams
vernier pulleys
stg 3 T34 hydrid turbo with 0.63 housing set for 2wd
2wd exhaust manifold conversion
4xgrey injectors
Group A spec k+n filter
mongoose stainless exhaust with debaffled rear box and 4in tail
racetec rs500 intercooler
racetec alloy rad
Group A spec 8.5mm plug leads
Group A coil
breather system and catch tank breather
set up and live mapped to 30psi
john
vernier pulleys
4xgrey injectors
racetec alloy rad
Group A coil
john
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
