Smoke on start up. Stem seals or Turbo??
This is on my 2wd sapphire.
On start up and running at idle when I rev it, it smokes a fair bit (mainly blue but also slightly black).
My guess is that its the stem seals have gone. I am changing the head for a reconned one. The problem is I don't want to spend time doing this to find that its the turbo smoking!!
How can I tell at this early stage??
The turbo is a T34 which has abot 15,000miles and about 5 years old.
The engine has 111,000 miles on it and as far as I'm aware hasn't had a head rebuild.
I couldn't be a problem with the bottom end! Could it??
Thanks
Stew
Thanks
Stew
cheak the boost pipes from the turbo to cooler for oil
but as dean says , sounds like rings maybe even pistons, whats ya oil temp like
do a leak down test to see is its the stem seals too
Will do the above.
I have a spare bottom end which is wire rung. Do these wire rings need replacing if they have already been used??
Anybody know the rough cost of a standard bottom end rebuild?? Providing you do it yourself??
B19bal: I've got a couple of pics of your car from when I owned it. Keep meaning to post them up. Will have a look for them.
Thanks
Stew
if engine is cold, and it smokes on start up then its likely to be v.s.o.seals if it does it when the engines warm its likely to be rings etc, but thats not gauranteed either way but its quite likely to be that
Strut brace: Those leads did the job
Only really noticed the smoke from cold but it doesn't really clear itself after a few revs, which stem seals would?? Will check when it gets warm tomorrow (tomorrow will only be the second time I've taken it out on the road)
Retest for the MOT
STew
Retest for the MOT
STew
Originally Posted by stew205
B19 bal heres a couple of pics before the other wheels were fitted.
aye ginge's car looked well there before he fookin wrecked it putting those shit wheels on
Originally Posted by rs nuts
stew could be a few things main probs are rings valve guides and stem oil seals
i have never out of 29 cossies had a turbo go yet m8
i gotta get a piccy up of what it looks like now
notice the badges and castle stickers gone and now for a MSD sticker on it, oh and the fogs and gril are gone and meshed, full leathers,,,,,,,,,,,,,, infact its hard to beliove it looked like that
ya got the original version of the pics or them in abigger size
Gadget
Aug 13, 2015 08:19 PM
