whats pectel all about???? (2.1 zvh engine)
Old May 4, 2005 | 10:05 PM
gavintwopies's Avatar
gavintwopies
Default whats pectel all about???? (2.1 zvh engine)
As above i'm just in the middle of gathering all the cosworth bits i need to go to cosworth managment and i've hit a problem????
I've seen some people with pectel boards in there cosworth ecu's to help with active spark control ( what ever that means?)
But on the other hand i've also seen people run cars on std ecus too ( not very well though)
my question is what does the pectel board do and is it worth getting an ecu with it already fitted, i've made some enquires and the best answer i got was that the std ecu will not run the dark green injectors that i will need, but on the other hand i've also been told that a re-mapped chip mounted directly on to the main board will also run the dark greens without the use of the pectel board
so before my brain bursts out of me skull will someone please put this to rest for me please.............................????
JoeyBoyden
Jan 4, 2024 02:36 PM
blackbeautyzetec
Sep 11, 2015 03:10 PM
Porplus12
Sep 10, 2015 07:20 PM
Rsmat
42
Sep 1, 2015 09:39 PM
muz
Aug 16, 2015 12:57 PM
