avo rear coilovers
am in the process of fitting the rear coilvers an have noticed that they have 3 small red bump stops on the shafts is the right amount or should i remove one from each, its how they came. Also do i keep the standard bump stops on the original spring mounts or leave them? 3dr cos btw
