5th injector set up?
Old May 1, 2005 | 06:33 PM
cooler king's Avatar
cooler king
Default 5th injector set up?
i do nedd to get the engine set up right before i go for a little more power but ive been thikning of the 5th injector set up as it seems like a common thing to have. what im wondering is what exactly is needed to do the conversion and what sorts of prices are you looking at for getting the lot done and set up? are they really worth it? are there any problems that can arise for having it done?
any help appreciated!!!!
cheers, phil
Old May 4, 2005 | 09:18 AM
bzd32's Avatar
bzd32
hi there,
fifth injector kit is only needed if you are going to run high boost (anything over 15psi) because the KE fuel management cant put enough fuel in to match the air, so this is when the fifth injector comes in.
Once you reach a programed boost level the fifth injector starts to fire fuel into the air charge pipe (the one that crosses the rocker cover) and your safe to run higher boost levels. But if your only going to run about 14psi its not worth fitting as it will cost anything from £200 to £350.
hope this help
Old May 4, 2005 | 09:39 AM
glenis's Avatar
glenis
spot on BZD32
Old May 4, 2005 | 09:55 AM
Westy's Avatar
Westy
Originally Posted by bzd32
hi there,
not true
I run 18psi and dont have a 5th injector
Old May 4, 2005 | 11:06 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
The fuel metering unit can be modified to fuel more for higher than 15psi
Old May 4, 2005 | 11:29 AM
Westy's Avatar
Westy
exactomondo
Old May 4, 2005 | 12:27 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i dont run one, i run 21 -22 psi, with the fuel pressure mod, and it runs perfect, dont pink at all.
Old May 4, 2005 | 04:39 PM
rs_daz's Avatar
rs_daz
running 19.8psi no 5th injector
Old May 4, 2005 | 04:53 PM
Arjan's Avatar
Arjan
piece of cake to dump in lots of fuel, but at low and mid revs/off boost the a/f ratio is gettting way too rich= less power,carbon deposits.
Old May 6, 2005 | 03:29 PM
Rick's Avatar
Rick
Mine is flat out at 14 psi, ant its been modded quite a bit
Old May 7, 2005 | 04:31 PM
rs nuts's Avatar
rs nuts
i run a fith injector and run 19 psi was set up by msd but it is true you do get a lot of carbon deposits but you do feal the difference in my car now
Old May 7, 2005 | 05:28 PM
bzd32's Avatar
bzd32
how do you mod the fuel meter
Old May 7, 2005 | 05:38 PM
vroooom ptssssh
It Wasnt Me!
not sure, tuner secret's
Old May 7, 2005 | 05:48 PM
bzd32's Avatar
bzd32
bumer
Old May 7, 2005 | 05:49 PM
bzd32's Avatar
bzd32
my cars going in to MSD next week, i will ask stu
Old May 7, 2005 | 05:50 PM
rs nuts's Avatar
rs nuts
when i had another tuned they turned the fuel pressure up on my metering head
they took a sensor off and adjusted it behind it
im not sure if thats how they do it correct me if im wrong
Old May 7, 2005 | 05:51 PM
bzd32's Avatar
bzd32
sounds good
markk
Sep 9, 2015 08:11 AM
3doorcozmess
Sep 7, 2015 01:32 PM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
