should i split my engine?
Old Apr 30, 2005 | 02:39 PM
SapphyMike's Avatar
SapphyMike
Default should i split my engine?
I've got a 205 block thats had a rebuild with a YBP (small) escort cossie cylinder head on it.
Would it be worth more split or as a whole?
thanks
Old Apr 30, 2005 | 03:07 PM
Phil's Avatar
Phil
Jeebus
Well you can get £250 for crank, £100 for rods, £50 odd for the block, god knows how much for the cylinder head, probably £300 odd?
Cams are worth nowt, used pistons are worth nowt, but alternator, water pump, thermostat + housing, sensors etc all sell well.
Old Apr 30, 2005 | 09:04 PM
Ginge !'s Avatar
Ginge !
just finding my feet
well tbh the heads worth 450 quid all day long, the rest i would keep together and sell for 700 if ya know its sound
Old Apr 30, 2005 | 09:06 PM
abdr500's Avatar
abdr500
700 for a 205 built block thats 200 block money
Old Apr 30, 2005 | 09:09 PM
Ginge !'s Avatar
Ginge !
200 blocks fetch more tbh
just causer a few sell cheep dont mean thats the price
tbh 700 for a cossie bottom end i know a guy who would buy that if he never got made to buy a total engine
Old Apr 30, 2005 | 09:11 PM
abdr500's Avatar
abdr500
b19bal,
Old Apr 30, 2005 | 09:16 PM
Ginge !'s Avatar
Ginge !
its still a cossie engine and cheeper that a rebuild engine !!!!!
to rebuild a cossie bottom end aint gonna be cheep if ya melted down
what you think a 25 short engines worth and ya seen em sell for as i need a engine and tbh a 205 will be find for me as has been for others too
Old May 1, 2005 | 07:48 AM
Mr RS500's Avatar
Mr RS500
£700 is a good price for a 2wd bottom end
Think about it
a good crank sells for £400
rods £150
block£100
sump£70
oil pickup pipe £50
front pully £50
not bad is it
Old May 1, 2005 | 11:53 AM
SapphyMike's Avatar
SapphyMike
Cheers for your input guys, split it is then i think!
Old May 1, 2005 | 11:59 AM
Ginge !'s Avatar
Ginge !
think 70 for a sump is a bit high
same as 400 for a crank too
maybe im a tight fooker
Old May 1, 2005 | 12:05 PM
Mr RS500's Avatar
Mr RS500
Where do you get cranks from ( unground ) for less mate , because i sell them for that easily Also sumps sell for £70 again no probs
You are just a tight fooker
Remember these items are hard to find now ,,Most cranks have been ground
Old May 1, 2005 | 12:08 PM
SapphyMike's Avatar
SapphyMike
So what about my cyl head then? LOL
Old May 1, 2005 | 12:13 PM
Ginge !'s Avatar
Ginge !
head from 450 upwards as there a beter flowing head
again thats a lowest price i would think of, sure there have been a few gone for 600 mark, again as paul said there expensive new and also thee sort after alot more than cossie heads as standard
btw how the hell do ya class a small cossie turbo head, t34 a stage 1 engine
Old May 1, 2005 | 12:20 PM
SapphyMike's Avatar
SapphyMike
cos its a norris motorsport stage 1 running std injectors lol
Old May 1, 2005 | 12:21 PM
Phil's Avatar
Phil
Jeebus
Sumps go for about £20 on eBay!
3drRich
Sep 13, 2015 07:32 PM
EoinXR3
Sep 7, 2015 05:44 AM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
