5th injector part two
Old Apr 30, 2005 | 02:03 PM
doggydowg's Avatar
doggydowg
Default 5th injector part two
right guys ive got an adjustable boost sensor that is set to 15psi, ive diconectd the blue and brow plugs from the back of the manifold.
Which sensor should i have left in place?
And which sensor do i need to run the wires from the boost sensor ie earth the blue plug and have a broken circuit positive feed from the boost sensor so that when the bost sensor kicks in at 15psi this makes up the circuit activating the cold start (fith injector) so that i can go from 14psi to 17 psi
chears Paul.
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
155lee
Sep 6, 2016 11:10 AM
cos elle
Sep 16, 2015 06:37 PM
markk
Sep 9, 2015 08:11 AM
