New shape mondy rear suspension woes
Any one help with a diagnosis on my mondy. Both rear tyres have worn off on the inside, had a quick check (very quick) of the bushes etc no movement to see.
Been to Mr Ford they tell me that they sell lots of the suspension crossmember (£200+) Could this be my problem? They want £70 just to have a look at it. I don't think so.
Car has never been in accident or kerbed (safe driving) to throw off the rear tracking so am assuming there is something worn.
Anyone had any similar woes?
Any help will be gratefully recieved.
Gaz
Gaz
the MK3 mondys suffer badly from soggy bushes in the rear subframes, its very common regardless of age or mileage but obviously the older and higher the more likely, its 90% likely the cause of your problem, do you have any warranty left? if not your'e looking at about £400 quid to sort it
