setting timing with kent cam
Right ive got my engine all back together now i just need to make sure timing is all ok ive got tdc on bottom end ok its just the head im not to sure on.the head is fitted with a kent cvh 35 cam also ive a vernier pulley fitted.i lined cam up with the std pulley on via the arrow on it then fitted the vernier.which had a white paint mark on it so i presume this would be right.as if i had std pulley on this would be pointing in right direction.i only need to get it running then go get it all set up propperly before running engine in.....just dont want to bend a few valves in process
cheers
jon
cheers
jon
Use the timing disc provided in the Kent kit. DONT USE THE TIMING MARKS!
Find TDC, fit the disk to the pulley bolt, and attach a wire to the rollbar as a marker. Rotate the crank to the degrees listed for your cam (118 degrees BTDC but check to make sure)
At this point No1 cylinder inlet valve should be fully open (I'm going from memory here so please check the Kent instructions). You can measure this using a tappet in the bore. I must stress at this point, that during this procedure, no rocker arms are installed!
Having determined this point, slip on the belt, and using the vernier pulley adjust back to the desired position before nipping up the bolts. You can now install the rocker gear, and turn the motor over by hand a few turns to ensure nothing makes contact (without sparkplugs in).
It should then be safe to fire up the engine once everything else is together (prime the oil pump).
Good luck!
Good luck!
jessie_rs
11
Jun 3, 2019 04:57 PM
