Eprom maps
Old Apr 28, 2005 | 05:22 PM
yrkesman's Avatar
yrkesman
Default Eprom maps
Friend of mine told that there was a while ago some discussion how to find ignition and fuel maps from the cosworth eprom? I'm trying to figure out P8 ecus eprom.
Old Apr 28, 2005 | 05:29 PM
Stu @ M Developments's Avatar
PassionFords Creator
This is probably the closest to that pal:
https://passionford.com/forum/viewtopic.php?t=93911
Old Apr 28, 2005 | 05:35 PM
yrkesman's Avatar
yrkesman
Thanks Stu.
Old May 3, 2005 | 05:32 PM
Your Welcome pal.
Old May 3, 2005 | 05:40 PM
ECU Monitor Enthusiast
Finding the maps is the easy bit (relatively)
BUT...
Even if you know where they are and how the data is TRULY represented....
Dont forget the checksums, the P8's checksums(s) are not a contiguous calculation
as areas of the eprom are not used as the internal flash memory overlaps the
eprom address space !!!
If you make a change to the map and NOT the checksum(s) , the ecu will either ....
1) Not run at all !!
2) run in limp home home (I.e rev /boost limit)
3) will switch to an alternate fuel map
Or it may work (unlikely) - all this depends on the original mapper who made your chip in the first place !
When I did it all those years ago,
it took me 1 hour to find the maps, and 1 month to suss out the checksum !!
Unfortunately this knowledge will not be free
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
