fiesta rs turbo steering rack
Old Apr 27, 2005 | 05:07 PM
UKMICKY's Avatar
UKMICKY
Default fiesta rs turbo steering rack
can any body please help
ford have discontinued making the steering rack for the ford fiesta rs turbo, but the shop says i can use the standard fiesta rack instead.
however apart from it not being a rs part can it be used. i know the rs has a wider track than the other fiesta's so will it make a difference as im in urgent need of a replacment
Old Apr 27, 2005 | 06:32 PM
daz1968's Avatar
daz1968
The RS rack is different, I had a problem with mine, where the bottom arms had been replaced with std fiesta ones, and I couldn't shorten track rod ends enough to get tracking right so I presume rack is longer, I put correct bottom arms on and problem went away, then at a later date I needed new rack, got one exchange from motor factor, You could always phone around as someone who rebuilds racks would do yours if they have none to exchange, the riesta rs rack is also got less turns lock to lock so is a quicker rack, I would made sure I had correct one when I did mine.
Hope this helps
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
borboyous
Aug 22, 2015 11:17 AM
