Just done the head gasket on my 2wd cossie and i've put it back together and now it won't start so i've done all the usuall checks and found that it sparks only once and it won't spark again until you turn off the ignition and try it again.
The spark once, sound like just the pulse from the amp, had this once
myself and the ecu plug was loose. also check the phase sensor in the
distributor,
