PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   Cossie won't start Please help (https://passionford.com/forum/technical-help-q-and-a/51611-cossie-wont-start-please-help.html)
killerscum01 Apr 26, 2005 06:53 AM
Just done the head gasket on my 2wd cossie and i've put it back together and now it won't start so i've done all the usuall checks and found that it sparks only once and it won't spark again until you turn off the ignition and try it again. :wall: :wall:
please please help
Cheers Bart
Niall.b Apr 26, 2005 08:27 AM
Could be loads of stuff & hard to say without looking at it. try cleaning the crank pickup sensor & teeth on crank pully, may not be registering????
davidreader5 Apr 26, 2005 12:11 PM
HI,
The spark once, sound like just the pulse from the amp, had this once
myself and the ecu plug was loose. also check the phase sensor in the
distributor,
DAVE R
cossieblood Apr 26, 2005 08:47 PM
PHASE SENSOR MATE
killerscum01 Apr 30, 2005 06:47 PM
Got it sorted after some probing, turned out to be a loose connection to the distributor (phase sensor).
Thanks for your help. :content:
© 2026 MH Sub I, LLC dba Internet Brands
