XR3i to RST
Old Apr 25, 2005 | 07:42 PM
fast_ford_fanatic's Avatar
fast_ford_fanatic
Default XR3i to RST
Ok, I don't want silly answers here, I want to do it just because I got nothing better to do!!!
Here's the question, has anyone converted an XR3i wiring loom to accept an RS Turbo engine. I got a mint engine, gearbox, ECU's, Turbo, ETC and I want to stuff it in my 3i the only concern I have is the wiring, how do I do it? Do I cut and join or completely replace? or do I simply add the missing wires in? I would like to know how YOU did it please. Yes I do have a S2 Wiring loom to use.
No silly answers please.
Old Apr 25, 2005 | 07:50 PM
monty's Avatar
monty
is it a mk4 or mk5 xr3i? if its mk4 you'd be better using the whole rst loom its more or less a straight swap
Old Apr 25, 2005 | 07:59 PM
fast_ford_fanatic
It's a MKIV XR3i.
It sounds easy!!!
I just need to know from someone who's dunnit. I keep hearing it's simple but just need these claims backed up!! I,m not a dunce when it comes to wires, I just don't want to do more than I have to!!!
Old Apr 25, 2005 | 08:03 PM
monty's Avatar
monty
well im doing it to a mk5 and its a cunt. But think mk4 should be easy if you dont already have the engine you would be better going for a frst engine http://www.chardcars.co.uk/ then goto s2 the efi conversion he's done it the a xr3i
Old Apr 26, 2005 | 08:45 AM
bigjayrsrus's Avatar
bigjayrsrus
mk4 rst loom can be spliced but its a propa pig to do
tear the whole loom out by removing the dash
unplug everything
pull through the fuse box
the rst loom is colourcoded multi plugs
plug and play really
any probs guess were ya can find me for a fuller description
Old Apr 26, 2005 | 08:55 AM
wimble's Avatar
wimble
ive done this to my mates mk4 combi van its a straght swap out with old in with new
Old Apr 26, 2005 | 12:25 PM
davidnormanuk's Avatar
davidnormanuk
You can cut the XR3i wiring loom about half way along the drivers side door as the RST Wiring is the same to the back lights etc. All colours match up on the RST side apart from one extra wire a black and white one (I think) which I taped up and and left disconnected. You need to replace the front end wiring by ripping the dash out and pulling the loom through the fuse box hole out into the engine bay. Any probs give me shout. Took me a day to replace the wiring easy job.
Dave
Old Apr 26, 2005 | 12:43 PM
fast_ford_fanatic
Excellent work my friends!! Real answers that give me a real confidence boost to the whole thing!! Another couple of weekends and I'll be boostin all the way
Thanks a bunch
Old Apr 26, 2005 | 02:37 PM
bigjayrsrus
go 4 it dude we are allways ere
A.t.p
Oct 23, 2015 07:54 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
A.t.p
Sep 29, 2015 05:04 PM
Billy_RS
Sep 13, 2015 04:17 PM
