too hot????????
Old Apr 25, 2005 | 06:21 AM
cooler king's Avatar
cooler king
Default too hot????????
the car seems to get very hot even on small journeys???? plus thimorning, there was a puddle of water underneath the car, on i nspection it was coming from the headertank cap!!!!???????? the water is filled just below the max level, i dont know if its just water thats in it though??????????
Old Apr 25, 2005 | 10:18 AM
ON-UJAH's Avatar
ON-UJAH
Flush the whole system and refill following the instructions on the bottle of antifreeze. If you still have no joy, check the usual things and start saving for an alloy rad.
Old Apr 25, 2005 | 12:25 PM
glenis's Avatar
glenis
if you over fill the header tank, it will piss out when hot
its an expansion system IIRC, so when hot the water level rises up
maybe it pissed out when hot, and when you switched it off etc... it will get hot, they all do, thanks to the turbo being part of the cooling system route...
have you put an 82 degree stat in it yet ? and 4x4 fan switch ? to help in the short term, then get an alloy rad, and turbo cooler, i.e. like the pro alloy one
Old Apr 25, 2005 | 04:35 PM
cooler king
cheers guys!
i havent actually done the mod yet however, when im driving the fan is usually on, i think the tank is classed as an expaqnsion tank system, i have seen the lid leaking a tiny little bit but i tightened it up a little so should be ok now!!!! :-( did i see right somewhere that other than antifreeze theres another additive that you can add that will help cool the water????
whats the best way to flush a system out???
i need to look at the turbo coolers, mine is an s1 turbo unit on an s2 and it seems to get very warm also!!!!! :-(
Old Apr 25, 2005 | 04:44 PM
glenis's Avatar
glenis
an S1 turbo unit is not water cooled, thats why
GET WETTER WATER, thats the additive what your on about, i dunno where to get it from tho!
flush with a running hose pipe, backwards and forwards thru radiator etc...
Old Apr 25, 2005 | 05:37 PM
cooler king
oil cooled i believe????
wetter water, thats the stuff, maybe not much point in that though if im to upgrade anyway but will defo do the flushing this weeknd and will also try to get hold of the stuff to do that mod eventually!!! busy weekend this weekend, got loads to do to the car!!!! the list gets bigger and bigger!!! good job its a bankholiday!!!
Old Apr 25, 2005 | 06:18 PM
glenis's Avatar
glenis
oil cooled yes, which i think = dogsh!t
Old Apr 25, 2005 | 06:19 PM
cooler king
ahh!!! i was going to ask what the advantage of it is!!!!!!!!!!!!!!!!
Old Apr 25, 2005 | 06:20 PM
glenis's Avatar
glenis
nothing i dont reckon, thats why they updated it to water cooled as well, in the series 2...
oil doesnt cool as fast as water, i think
Old Apr 25, 2005 | 06:31 PM
cooler king
oh well!!!! another possible problem then????
on a nice sunny day like todaqy i fpound out the fuse box leaks!!!!!! :-(
Old Apr 25, 2005 | 06:33 PM
glenis's Avatar
glenis
probably wont be helping your temperature situations, every little helps...
althought water cooled ones, heat the coolant up as well, turbo coolers are best
how come it was leaking ? you poured water down ?
Old Apr 25, 2005 | 06:43 PM
cooler king
turbo cooler, i need to know more!!!! how much for a start!!!!
yeah, just a little bit, it doesnt help havin no fuse box cover either!!!!!!!!
Old Apr 25, 2005 | 08:06 PM
glenis's Avatar
glenis
turbo cooler from PRO ALLOY Ł100, ideally needs to bolt to the side of one of their intercoolers tho!
no fuse box cover!!! WHY NOT ???
get a cover asap, and then think about repairing it, welding needed i expect
Old Apr 25, 2005 | 08:16 PM
cooler king
hmm, sounds good! how do they plumb in?????
i was looking at their coolers anyway with thev2 fans!!!!!!
never had a cover!!!! :-( no welding will be needed!!!
Old Apr 25, 2005 | 08:29 PM
glenis's Avatar
glenis
get a cover, you dont want water pouring into your fusebox and knackering it out...
coolers plumb in to turbo coolant lines from main water coolant system, just 2 pipes...
get a cover if i was you
you got an ERST S2 or a puma ?!
Old Apr 25, 2005 | 08:38 PM
cooler king
both!!!!!!
i have temporarily put gaffer tape over it to keep the water off it!!! im bidding on a chrome cover on ebay as i cant find one ih a scrappy, i realised though that they clip over the originals, doh!!!!!!!!!!!!
Old Apr 25, 2005 | 08:40 PM
glenis's Avatar
glenis
you have both, how come ?
which do you drive etc... specs... ?
Old Apr 25, 2005 | 09:16 PM
cooler king
the puma is off the road at the moment as it doesnt want to start at all!!!!! i think its the clifford alarm! the rst is the new toy really, only just got it so its all new to me!!!!!
the puma no longer has the wheels on it that are in the siggy, it has the frp wheels on it now and the front and rear brakes are now st170, evertything else on thatcar is pretty much as it looks! full frp interior, full racing exhaust system, 4-2-1 manifold, modded ecu, air filter bit of a stereo, lowered but i hate it now its that low, needs to go back to standard springs on the konis!it needs the rest of the graphics doing on it, hopefully before the shows!
the rst is also red, 4" scorpion, -31, s1 turbo, chipped, bleed valve and thats about it, doors and boot are smooted and delocked! in the process of getting the bonnet smoothed off and getting a 90 spoiler, needs a very good tune doing to it abnd soring out of the wheel camber, bodywork is a little shoddy but will come up good! probably get some small white graphics on that aswell as having the wheels powder coated too.its also got green stuff pads with ebc discs, im not too keen on this set up either!!!!! this is also stupicly low, im after a set of original springs to go with the koni dampers for it!!!!!
Old Apr 25, 2005 | 09:19 PM
wildheart's Avatar
wildheart
No it dont
Old Apr 25, 2005 | 09:20 PM
glenis's Avatar
glenis
where abouts in manchester do you live ??
Old Apr 25, 2005 | 09:23 PM
cooler king
i actually live in ashton under lyne!!!! do you know it?
glenis's Avatar
glenis
This is what Ford thought when revising the oil cooled turbos in S1's
pahaha
Old Apr 25, 2005 | 09:24 PM
glenis's Avatar
glenis
where is A-U-L ?
Old Apr 25, 2005 | 09:27 PM
wildheart's Avatar
wildheart
Well ford are wrong
cooler king
near oldham.......ish!
Old Apr 25, 2005 | 10:08 PM
adamS2RST's Avatar
adamS2RST
Sounds like you need to flush the system, go and buy a new header tank and cap from ford (cheap enough) and see how you get on
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
