Saph dump valve...
Old Apr 21, 2005 | 02:41 PM
RsDarren's Avatar
RsDarren
From: Dewsbury, The parts were they don't abduct their own children!
Default Saph dump valve...
I know this may sound silly but where does the small vacuum hose connect to fromthe top of the dump valve in a saph 2wd cossie. The car didn't come with one, so now i have it i want to make sure i fit it correctly?
Daz
Old Apr 21, 2005 | 07:53 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
The inlet manifold should have a nipple you can plug the hose into, if not, there's probably a bolt blocking a hole, you just need to get the plastic bit that screws into the thread and allows you to attach a hose to it.
Whatever you do, DO NOT be tempted to cut the hose that goes to the map sensor and use a t-piece. That would mess up the map sensor reading big time.
Old Apr 22, 2005 | 07:56 PM
richm's Avatar
richm
in the pic here, you can see the pipe running round the slam panel to the dump valve, it connects to it's own nipple on the plenum chamber, the front one of the four originally. As Frog says, DON'T under any circumstances be tempted to 'T' it into MAP sensor or Pressure regulator pipes.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
