Ford Escort Mk3 GL electrical issues
Old Jan 19, 2026 | 03:38 PM
Nunget's Avatar
Nunget
Unhappy Ford Escort Mk3 GL electrical issues
(MOSTLY FIXED)
I just installed a new stereo (BOSS UAB508 60W) in my escort and started having some strange electrical problems.
The overhead clock turns on when I press the overhead light buttons (but the overhead lights do not turn on) and when the clock is on, the stereo stops working. The clock didn't work before I installed the stereo. The automatic shoulder belt also stopped working while I was messing with it last night.
When the stereo is on, it can properly output to the sound system until it's using too much power (???) such as when it tries to output at a volume higher than 25/40 or when it attempts to read a disk.
Posting here may be a shot in the dark, but looking at some posts y'all seem more knowledgeable than reddit. I don't expect to get a solution, but some pointers or mk3 escort wiring diagrams would be a big help.
Here's a video of me messing with everything.
I couldn't find a good site to host videos so all I have is a discord CDN link. I'm also not sure if it would even help lol.
https://cdn.discordapp.com/attachmen...1285747643f26&
Last edited by Nunget; Jan 19, 2026 at 09:34 PM. Reason: To label the problem as resolved.
Old Jan 19, 2026 | 09:33 PM
Nunget's Avatar
Nunget
Update: I took the clock down and unplugged it, and the stereo and shoulder belts started working again. The headlamps still don't work and the radio restarts itself when I go over speed bumps, but those are problems for another day.
For anyone who somehow found this after having the same issue:
Unscrew the exterior screw, then use a thin tool to pry open the headlamp covers, and then stick another thin tool (or a fingernail if you have them) under the opening. They will bend a bit but that's fine. Firmly pull them straight down once you have a good grip. You can now access the last screws holding the overhead assembly in place. Undo those yada yada the assembly will fall down, the wires will catch it.
NOW: the wire connector is very hard to remove. You will need to pry it open decently far while also pushing it out firmly. Eventually, the clasp will catch on the sloped bit of plastic. You can now push the clasp with one hand while pulling on the connector with the other. You do not need to disconnect the headlamps. Test your radio, then fasten the assembly back into place. Wahoo!
Totallyblownhemi
Jun 28, 2012 08:38 PM
Jimster
Dec 3, 2011 02:43 PM
cossie4i+
71
Jul 18, 2006 01:42 PM
MadMac
27
May 11, 2005 06:05 PM
