Sierra 2wd won’t idle. Doing my nut!
Old Oct 12, 2025 | 03:30 PM
Leloby's Avatar
Leloby
5 Year Member
Default Sierra 2wd won’t idle. Doing my nut!
I’ve got this thing nearly right.
All new loom, sensors, PF01, plugs etc.
L6 Stage2 on new proper Greens.
Starts on the button. Revs nicely.
It just won’t idle for more than 5-10secs.
All the settings are as per forum experts.
Im going to change Amal valve this week but wondered if it’s something obvious to someone else.
Cheers.
Old Oct 26, 2025 | 07:15 PM
Guinnless's Avatar
Guinnless
It should idle with the ISCV disconnected. Have you checked the base idle screw underneath the throttle body?
Old Oct 26, 2025 | 09:49 PM
Leloby's Avatar
Leloby
5 Year Member
got it now. Took plenum blank out and replaced one way air valve. Idles and goes great but won’t boost past 12psi due to voltage issue. Working on that now…
MARKYMARKONE
Oct 17, 2016 09:45 AM
mark r
Sep 11, 2013 09:06 PM
robby421
Jun 19, 2012 08:45 PM
Smokestone DOHC
Oct 20, 2010 10:01 PM
Harris.
Jan 22, 2006 05:17 PM
